Old 01-05-2009, 05:38 PM   #1 (permalink)
Exhaust Manifold/Cat for VX
I have a '94 VX and the Exhaust manifold is cracked and I was going to replace that along with the cat. I was wondering if the Dorman OE 674-439 would fit on my VX? That Dorman part is for 96-00 civics but I think I've read that the 96-00 Manifold/Cat will still fit on the VX. Can anyone confirm this? Thanks
Old 01-05-2009, 06:14 PM   #2 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
I googled "Dorman OE 674-439" which turned up this on line auto parts store that carries it.
When I look up '94 Honda Civic VX at the same store, it shows Dorman OE 674-545
So, probably not.
Old 01-05-2009, 08:25 PM   #3 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Honda Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
Seeing as you're in the Bay Area, you might want to try giving HAP a call.
www.haprecycling.com - honda and acura car parts
They're a Honda/Acura salvage yard in Rancho Cordova (Sacramento), not too bad of a drive. I made it once when I was living in Foster City.
Old 01-05-2009, 08:43 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
MMK - you have the cool manifold that the catalytic convertor connects directly to, in front of the engine.
1 - Any Civic CX
2 - Any Civic VX
3 - 4th gen Civic STD
4 - 2nd gen CR-X HF.
The only thing is that you must use the same catalytic convertor as the manifold you have - the bolt patterns are different, except maybe the CX/VX ones.
In theory, depending on your emissions laws, you could get any D-series header and cat combo, and you'd just have to slightly modify your exhaust to fit it in there... the B-pipe would have to be cut and welded to length.
Most of the images for headers on RockAuto.com show the basic header from the 4th gen Si Models... they're all nearly identical, from 88-00, so they're basically interchangeable. The one that you need is the one that has the cat sitting directly in front of the engine, which is CX/VX and HF/STD models. Some DX models apparently also had it. Year is not a concern, as long as the engine is 1.5 liters or has a engine code beginning with "D" (D16Y7, D16Y8, D15B2, D15B8, etc.)
Old 01-06-2009, 12:40 PM   #5 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
If your cat converter is still good and just the upper manifold is cracked...I do have my old VX manifold sitting around collecting dust. You can buy it off me and I can ship it to you.
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 12:31 PM
Exhaust manifold wrap? chuckm EcoModding Central 6 10-29-2008 11:56 AM
Replacement Exhaust/muffler 97 Metro RedRocket321 EcoModding Central 28 07-06-2008 02:58 PM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
