Difference in displayed vs measured MPG: Statistical Analysis
In the garage, I have recorded the MPG displayed on the factory gauge for almost every fillup. Leaving out the two I missed, there are 178 fills with these data. Since I'm taking a statistics course this semester, I thought it would be fun to run a simple analysis. Here's what I found:
https://ecomodder.com/forum/member-v...played-mpg.jpg Using the quartile method to identify outliers, I removed two data: the two times when the factory display underestimated calculated MPG. The remaining 176 fills chart nicely into a normal curve. Median = 3.0 MPG difference Mean = 3.04 MPG difference https://ecomodder.com/forum/member-v...played-mpg.jpg Percent difference shows an even clearer normal curve, and again median and mean are very close to each other. Median = 5.58% difference Mean = 5.563% difference |
