Old 07-31-2008, 12:20 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
whats so hot about metros?
do they give the best MPG or are they just the cheapest?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 07-31-2008, 12:32 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Both!
You've probably figured out by now they're not the same as the Metro you had/have in the UK. (Rover?)
Old 07-31-2008, 02:28 PM   #3 (permalink)
Audi A5 - '10 Audi A5 2.0T Premium Plus
90 day: 30.17 mpg (US)
Prius - '12 Toyota Prius Four
90 day: 51.86 mpg (US)
D
... no AC
Old 07-31-2008, 04:09 PM   #4 (permalink)
My two thumbs up go to 1) small engine with a good cam (xfi) and 2) tall gearing. Those two things alone could bring a normal car's mpg up 25%.
Old 07-31-2008, 05:09 PM   #5 (permalink)
what do you mean by good cam Daox ?
Old 07-31-2008, 05:10 PM   #6 (permalink)
are the metros all 1L petrol engines ?
Old 07-31-2008, 09:13 PM   #7 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Most Metro models are the 1.0L 3 cylinder gasoline engine, but some came with the 1.3L 4 cylinder engine. The standard shift 5 speed was best for fuel economy.
A good cam would be a swap from a Metro XFi model which was ground for fuel economy or having your cam reground. There are also lots of other MPG improvements to be made to the Suzuki engine such as and advanced timing gear, ignition timing, exhaust upgrades, etc.
40+ MPG easily if it's running right
Really fun to drive
Easy to work on
Park it anywhere
Roomier than expected interior
Good in snow with the stock tires and height
Getting rare in certain parts of US and Canada
Cute?
I am an older guy who used to love muscle cars, but ever since this little car came into my hands, something strange happened to me and this weird addiction with a "piece of crap" is overwhelming. I actually feel like I am 16 again with my very first car.
You either love them or hate them.
GeoMetroforum.com - got mpg?
Old 08-01-2008, 10:42 AM   #8 (permalink)
When I got Firefly #1, I immediately noticed it was much hotter inside parked in the sun compared to the '89 Accord it replaced.
And it makes sense - the '95s and up have steeply raked front glass, and a high glass to interior volume ratio (higher than the Accord for sure). That's a BAD combination for the old greenhouse effect.
Old 08-01-2008, 02:58 PM   #9 (permalink)
My first metro was a '93... bought it in the winter, figure, naaa, I can live without AC.
WRONG It sucks, my commute includes stopping in traffic.
Took over 6 months on ebay to finally find one that had AC, 3cyl, 5spd that wasn't JUNK. Paied $2900 for it a year ago when gas was ONLY $2ish a gallon.
What I DIDN'T notice, it was rusting from the inside out. Shortly after, what I thought was mild surface rust under the paint, I can stick my finger through the rockers, 6" hole in the back inside wheelwell... It leaks water to the interior, I could never find the leak, so I had to rip out the carpet off the bottom, and drill holes for it to drain when it rains! Then I found the wheel well problem...
I plan on driving this under the doors fall off...... and then I'll just weld them on
Luckily, the framework is not too badly rusted, I can still wire brush that and paint before it gets too bad.
Old 08-01-2008, 04:21 PM   #10 (permalink)
igo
igo's Avatar
Mini Box Truck - '05 Scion Xb
90 day: 32.87 mpg (US)
It FITs - '09 Honda Fit Sport
90 day: 36.2 mpg (US)
Impreza - '13 Subaru Impreza Sport
90 day: 30.92 mpg (US)
Well, they get the best mpg of any non-hybrid in America. I would assume that is why everyone here likes them.
Keeping Engine Coolant Hot Raysp30 EcoModding Central 18 12-08-2011 07:57 PM
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
how hot is too hot for metro? SirKeats DIY / How-to 5 08-02-2008 02:27 AM
How hot is too hot for a Metro/Swift Wayneburg General Efficiency Discussion 3 05-07-2008 09:12 PM
Seeing lots of Metros on the road lately jwxr7 General Efficiency Discussion 4 04-22-2008 10:47 PM
