EcoModder.com
-   -   digitaldissent's Yaris sedan build thread (https://ecomodder.com/forum/showthread.php/digitaldissents-yaris-sedan-build-thread-2704.html)
digitaldissent 06-01-2008 08:31 PM
finished my prototype upper grill block, coroplast is hard to get on a sunday, thank you local elections.
I just sprayed it black, will get some black coroplast soon and re-do the upper section in one piece
http://www.killrobot.com/images/grill_block1.jpg
Next up:
1.fix factory lower air dam (tweaked by driveway)
2.smooth transition over from front fog light openings
3.partial lower grill block, install walls behind bumper to direct air
4.re-engineer air dams forward of the wheels
5.more to come...
Daox 06-01-2008 08:41 PM
Looks great. :thumbup:
Blue07CivicEX 06-12-2008 08:22 PM
where do you get coroplast? (what type of store?)
reformed 06-12-2008 09:02 PM
Check with any local sign store that makes their own signs in house. They should have some in stock or be able to get it for you. Wholesale cost on a 4'x8' sheet was $8 a few years ago when i used to be in the business and it couldn't have gone up a whole lot since so don't overpay!
Blue07CivicEX 06-12-2008 09:15 PM
Excellent!! you have no idea how helpful that is! I still think I'm going to try Fiberglass for my rear skirts but coroplast would be good for my front and some of the underpan.
Another New Yorker, I'll actually be in Buffalo for the next two weeks for business, I'm using the drive out and back as a test for my temp front end work.
ttoyoda 06-12-2008 09:55 PM
That car looks really sharp with the grill block.
I wonder how it would be with this kind of decoration on the blocked part:
http://www.defenselink.mil/home/feat...gers/p-40a.jpg
Motivate people out of the passing lane maybe...
digitaldissent 06-12-2008 11:44 PM
photoshop GO!
SVOboy 06-12-2008 11:45 PM
Looking forward to seeing the photoshop results, :)
mopo3 10-14-2008 10:54 PM
I GIMPed my yaris grill
http://lh4.ggpht.com/matthewmoroz/SP...ock640x480.jpg
Above: GIMPed
Below: Original
http://lh5.ggpht.com/matthewmoroz/SP...nt%20grill.jpg
