EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Dimpled Bottom? (https://ecomodder.com/forum/showthread.php/dimpled-bottom-16960.html)
capnbass91 04-21-2011 06:02 PM
Dimpled Bottom?
At some point I want to cover the bottom of my car, to make it more aerodynamic, and I remembered watching a Mythbusters episode where they covered a car in dimples like on a golf ball. So if I were to somehow put dimples in the material I used to cover the bottom of my car, do you think that would help me get better mileage?
XJguy 04-21-2011 07:02 PM
Short answer is no.
Joenavy85 04-21-2011 07:28 PM
add about 600 pounds of clay to the car and dimple the whole thing and it might help, but any gains at that point would be negated by the extra weight.
Not to sounds like an butthead (since anything more i post will get censored) but you can find most of what you are looking for by doing a search at the top of the page, rather than posting the question as so many others have
gone5 04-21-2011 08:10 PM
I swear I remember seeing a car commercial a few years ago that mentioned dimpled underbelly to improve aerodynamics.
XJguy 04-21-2011 08:20 PM
If it would work, you would see planes covered in bumps.
zonker 04-21-2011 08:32 PM
personally i like the dimples just above the bottom.
dimpling the bottom itself just looks like cellulite
sorry couldn't resist.
capnbass91 04-22-2011 01:40 AM
hahahaha cellulite hahaha
so the answer is no, got it, thanks!
Ryland 04-22-2011 08:52 AM
There are vehicles that do have dimples on them like the Corbin Sparrow, but even it only has dimples on the trailing curves, if you have a straight smooth run then it's best to keep it straight and smooth, it's easiest to keep it straight and smooth as well.
