10-21-2009, 09:36 PM
Mercedes aero engineer: Cd of .20 feasible in production cars within 10 yrs
Found an interesting article about Dr. Teddy Woll, head of aerodynamics at Daimler. There's no date on the piece, but judging by the absense of discussion of the Cd 0.24 E Class coupe, I'm guessing it's older than this year.
He talks about the challenges and opportunities in making cars ever more aerodynamic, which is a stated goal of Daimler - see Mercedes to Sell Super-Aerodynamic Cars in 5 Years | Hypermiling, Fuel Economy, and EcoModding News - EcoModder.com .
Answers questions like:
Which components of cars do you believe have the greatest potential for aerodynamic improvement?
"The big action is at the rear," of course. (No news to EcoModders.) And he describes things the company is doing, and what it could potentially do. Plus chatter about wheels/wheel wells/underbody.
What do you think is the lowest drag coefficient possible for a mass production car?
Spoiler alert: Cd 0.20
He uses the GM Aero - Cd. 0.14 - as a starting point of an "impractical" aero car and lists several of its unacceptable aero features that would need to be compromised for reasons of safety/performance/practicality.
Not sure if he's referring to this car "GM Aero 2000"
Anyway, worth a read:
"A Drag Coefficient of 0.2 Represents the Sound Barrier" - ATZ online
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
10-21-2009, 09:50 PM
...beats walking...
...the date on the picture is "woll_090130.jpg" which seems to imply Jan 30 2009, so it could've been late 2008 or early 2009.
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
10-21-2009, 10:34 PM
In the 1980s, a few prototypes were created that were used to sound out the limits. For example, the GM Aero had a drag coefficient of 0.14. It had completely smooth wheels and a completely smooth underbody. The angle of the windscreens meant that it heated up to very high temperatures in the sun and it had no brake cooling, no cooling air system and no seams on the bodywork. If you were to use this shape, which would not fit into a standard garage, to create a production car, you would have to add at least 30 or 40 points, which would bring the drag coefficient up to 0.18. If you then shortened it to a length that is suitable for everyday use, the figure would increase to 0.2.
That is confusing- his comments about the GM "Aero".
The Aero X certainly looks garageable... has body seams... so it shouldn't be that.
The Aerotech- especially the longtail- is long enough not to be garageable... has no seams really... but it's obviously not a road car... has no back window either... has cooling openings...
Maybe his memory has failed him and he's got these two cars combined in his mind? Or there's another GM aero car we don't know about?
The length of the rear end can reduce drag by between five percent and a maximum of 15 percent. However, in the case of a 15 percent reduction, the rear end would be so long and narrow that it would probably be difficult to get a suitcase into it widthways.
A perfectly designed full boat-tail on my Tempo would get me from .36 to .306? I thought they were potentially worth more than that...
10-21-2009, 11:21 PM
Pokémoderator
Old Tele man -
Good web detective work. I use that trick too from time to time.
CarloSW2
10-22-2009, 06:38 PM
Lets see. I have a car that has no problem fitting in a garage, has no problem with excessive heat buildup inside from the angle of the windshield, no problem with brake cooling, has a cooling air system (is he talking about the engine radiator or the A/C?), and is practical enough for daily driving all year around. And its Cd is.....
The Following User Says Thank You to basjoos For This Useful Post:
10-22-2009, 08:24 PM
...beats walking...
...there's INSIDE-the-company mindsets and OUTSIDE-the-company mindsets.
...let me guess, Dr. Woll's was INSIDE "M-B" and not INSIDE "GM" for sure.
The Following User Says Thank You to gone-ot For This Useful Post:
10-23-2009, 02:20 AM
i recentyl came accross this article about the pinafarina aero car experiment with an 0.201 Cd it wouldn't look even half as unconventional today as it did back than.
Popular Science - Google Boeken
also it just seems to get the basics right, and without compromising practvality or intyroducing shapes that would be difficult to make.
if you start with the best possible shape and that make a few compromises to turn it into a car you'll always end up with something better than when you make a car and than compromise the styling to get it a bit aero
aerˇoˇdyˇnamˇics: the science of passing gass
*i can coast for miles and miles and miles*
The Following User Says Thank You to lunarhighway For This Useful Post:
10-23-2009, 05:02 AM
aero guerrilla
Oh, my! The banana car
eˇcoˇmodˇding: the art of turning vehicles into what they should be
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
10-23-2009, 11:32 AM
#9 (permalink)
The Following User Says Thank You to moorecomp For This Useful Post:
10-24-2009, 08:59 AM
#10 (permalink)
What ever happened to that Benz Boxfish prototype?
