Display shows increased mpg with higher rpm
I thought the general consensus is that higher rpm=higher fuel consumption, but if it is so, then why does my onboard computer display show my fuel consumption decreasing with higher rpm when accelerating in same gear?
I can only think and explain that in terms of fuel delivery rate, lets say 2 ml of fuel/second is delivered when the pedal is pressed at 50% at 2000 rpm in second gear at 30 km/h , and rising to 4000 rpm=60 km/h but with the same amount of 2 ml of fuel being burned. So why should I change at lets say 2700 rpm if the instant consumption decreases as it accelerates to higher rpm ? |
Are you sure the display is accurate? Depending on the engine design and what kind of camshaft the engine has, it is possible to have higher efficiency at higher engine speeds, just not likely. Over 3-4 thousand rpm, friction increases and efficiency is lost as pressure in the exhaust builds up.
Well I don't really know if this is true but my grandfather has always said that all cars have a "sweet spot" where you get the best fuel economy so perhaps that's the case.
But what kind of car do you have? |
MPG is a measurement of fuel usage compared to distance. When you begin accelerating you are covering less distance over a given amount of time. As the speed of the car increase it covers more distance on a given amount of fuel up to a point.
1 Attachment(s)
1.5 japanese engine , suzuki sx4 2009 (torque power graph in attachement)
I dont have the gear ratios, all that I can say is that 1st gear max 50 km/h, 2nd 100 km/h, 3rd 140 km/h, 4th 180km/h, and 5th . |
I dont really remember instant fuel consumption above 4000 rpm, but below 4000 the instant fuel consumption definitely decreases as rpm increases to 4000. Yeah in this topic I'm reffering to instant mpg or instant fuel consumption not averages. |
Since at 4k it uses more fuel than in 2nd you would want to be in 2nd. Now make those comparisons at 2K, 2.5K, 3K, 3.5k and in each gear. This will give you an indication of you best shift point vs FE. One other consideration not to accelerate too slowly.
It looks like you get peak torque at 4100 rpm, and from the jumpiness of the torque below 4k im going to assume the engine has variable intake runners. From what I have seen, most engines achieve their best bsfc (brake specific fuel consumption), while operating below peak torque and not within 200rpm of peak torque. For your engine that would be 3100 - 3900rpm.
Before I stumbled upon the information on this forum, I was using very light pedal with ~3000-3500 rpm changes, and now I'm using heavy pedal 2500-3000 rpm change and lower average consumption. |
You'll want to keep an eye on fuel/hour gauges just to be sure you are in the right spot, but I think you will see best results between 3100 and 3900.
In my 2.3 Petrol Mercedes with an MPGuino, I always saw a dip in consumption at 1800rpm (every load/gear), which I presume meant that was it's BSFC sweet spot.
