Displaying voltage, oil pressure, oil temp etc.
Hi,
I stumbled over the MPGuino site and realized that I need to look closer into that topic. Actually I just want to install a plug and play ScanGauge system, however my car does not have an active OBD plug and no electronic fuel injection. It is an old fashioned diesel car with mechanical fuel injection. My main focus is not displaying fuel consumption (however, it would be nice), however the following classic gauges are of my interest: 1. Oil pressure 2. Oil temperature 3. Voltage 4. Amps 5. Outside temperature The thing is, that all these gauges are perfectly available from manufacturers such as VDO. However, their diameter is too large and will not fit. Moreover I want to display many gauges and there just is not any space for that. Thats why I need a compact digital system. So basically its all about handling sensors which change their resistance values (or voltages) and display these values on a small screen (with conversion factors). For that purpose I want to install a basic lcd display module into the DIN Radio compartment of the car. The dimensions are approx. 175x50 mm. Can anyone help in guiding me into the correct direction of that project? Lucas |
I've actually wanted the same thing for years - so I built one. The first version used a PIC16F877A microcontroller and serial LCD module from sparkfun.com, as well as a handful of temperature sensors (DS18B20) and a pressure sender meant for a prosport gauge. I designed a DIN slot adaptor in solidworks that would hold the gauge as well. Never ended up installing it though, got distracted rewriting all the code for a 32 bit microcontroller. I still have the 8-bit code if you're interested.
Chris |
yah it is a pretty simple task for the code. I think arduino is a good fit for this, lots of examples of displaying values on an lcd and the microcontroller has several analog ports. The hardware interface is pretty simple too if taken one port at a time.
1. Oil pressure: might need aftermarket sensor and a tee, but divide it to a 5v peak signal. 2. Oil temperature: same as temp 3. Voltage: use voltage divider (can use internal resistor in processor as part of divider) 4. Amps: use shunt and op-amp, or use hall effect sensor. 5. Outside temperature: thermistor as part of voltage divider Each of these will look like an analog signal to the arduino (basically an atmega) and the basic arduino comes with six analog ports. setup: init lcd and analog ports loop: read pressure on pressure analog port update pressure on lcd read oil temp on temp analog port update temp on lcd ... |
I would be REALLY interested in something like this.
I only want MPG, and for a Honda, and for OBD1 (like a 93 civic). I would want instantaneous and a resettable average. Anyone interested in building one? |
that is pretty cool!
how much donation is typical? |
$55 shipped, but it is on hold till the current backlog clears. Though with you building cars and stuff, you might do well to build one from an arduino and learn a bit about microcontrollers, etc. See the version 1 thread and the wiki.
