DIY/Cheap mirror delete
5 Attachment(s)
I removed my passenger mirror and made a cheap/free cover for it, I have not installed it yet because it has been raining and I think I am going to silicone it on (which won't cure in rain)
Attachment 14957 So, here is were the mirror used to sit Attachment 14958 Here is the old mirror Attachment 14959 This is the old gasket that I used as a stencil to make the cover Attachment 14960 This is what I made the cover out of, it is the middle of a lid for a plastic tote. We cut the middle out of the lid so we could use it for our chicken brooder. Anyways, it was just layin around the garage, so I decided to use it. Attachment 14961 This is the cover mock up on the car. I have already done the final fitting and painted it, it just needs to be put on the car. I am going to use silicon to make sure it doesn't leak or anything. I'll post pics when it is done and let you know if I have any air leaks or anything. Thanks for checking out the post. Got any ideas or anything else to add, please feel free. |
It looks like a good start, can't wait to see what the final product ends up looking like. Are you going to reuse the original gasket or rely on the silicon? I especially like the use of extra material instead of throwing it away or buying new stuff, good re-use/recycling! :)
Also, I assume you checked your local laws about side mirrors... |
Yes, I did check with local laws, you need a mirror attached to the side and either a center mounted or additional side mounted mirror. I wound up getting impatient and just siliconed them in the rain and covered it with a plastic bag. There's no end in sight to the rain.
Anyone ever replaced a side mirror with a motorcycle mirror and noticed any difference? I mean, you can pick one up on amazon for like ten bucks, but if it doesn't make a difference, then ten bucks is ten bucks.
silicone emits acetic acid on cure and reacts with steel. neutral cure silicone is best. not much steel except that screw so you should be good.
ASI 335 Neutral-Cure Silicone Sealant/Adhesive |
Looks nice! Some mirror deletes are UGLY! Nicely done.
The side mirrors on my cobalt are kinda triangle-shaped, I've been thinking about switching the left/right mirrors and mounting them so as to have a bit slimmer profile. Instead of the "point" of the housing protruding outward, have it point upward. Like rotating a 30/60/90* triangle.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
