DIY engine stop/start, with clutch + throttle switch restart
https://www.youtube.com/watch?v=5nYAJcBx3Dc second attempt is my Hyundai Santamo. The kill switch is now right hand operation and cuts the injection. And it is self holding. Way better, for engine braking, as deep down as you want. a little slower at restart. i countered this witch a hypersensible throttle switch. https://www.youtube.com/watch?v=YHlrii6L64Y the simple kill switch alone makes about 90% of the trick in my case. the self restart is barely used and avoidable. at the end of the last video is shown a stop without a restart. https://www.youtube.com/watch?v=UwLDSEh1Ty4 i used the build in injection relais to kill the engine. thats the first step. second is restart, the technik is simple. a circuit: 12v batterie - throttel - clutch - service switch - relais coil - 12v alternator messure out the thin pin at the alternator, witch goes from 0v to 12v when the engine is running. the 0v are basicaly ground. so the relais is operating when the engine is not turning and all switchen are closed. this relais leads 12v to the starter. done. |
kurzer -- very interesting. I think I like that clutch/accelerator restart.
Do you have a dedicated thread documenting this project? |
sorry, there is no thread about it. but feel free to ask, iŽll try my best to explain.:D
the clutch+Throttle restart works verry well, indeed. i put the car in gear and wait for green. the normal feet movment starts the engine at the latest possible moment. |
kill switch
I'd like to install a kill switch too. Today I stop the engine while driving by switching ignition off by turning the key for two seconds. Not a safe way. It happend that in a situation of heavy traffic I forgot to switch it on again and wondered why the engine won't start again. The other point is that everytime the ignition is off the light goes off too. Imagine someone is behind you and once a minute his light goes off for 2 or 3 seconds. Even more trouble if the Police realizes that. Until now I was lucky but one day ... The reason why I didn't install this kill switch (or better said ignition off pushbutton) is that I have no idea which cable I have to cut. To mount a relay and a switch isn't a problem for me. As my car has a manual gear it's rather easy to start the engine again as far as the car is still rolling or just by key after long stops at the traffic light. |
moved to dedicated thread
Hi kurzer -
I moved the discussion of your project into this new thread. (Note, it was previously inside: http://ecomodder.com/forum/showthrea...art-34076.html ) --- I have a question too: how does the clutch+throttle switch control how long the starter is engaged? |
What are the options for us guys with automatics?
@ Jurgis without the wiring diagram no one can say. but u better go for the injection relay than the ignition. otherwise the fuel is still dripping...
jic: when the alternator fails and the starter will not stop, u have to open the service switch. |
true egnough. sometimes i hit the gas unintended and the starter kicks in. sometimes on purpose, but normally i double clutch for restart. that is the softest rolling restart possible.
So, can you restart it pressing only the throttle in case the engine stalls?
clutch and gas needed for restart. if u stall the engine with the feet on them, the starter kicks in. in case of engie trouble one can even drive a short way electrically.
Have you ever considered trying to add some mild-hybrid ability to that?
no, not with the starter...
Sure it wouldn't feel so comfortable to do so with that stock starter. If a starter-generator similar to the ones used in some small aircraft wasn't so expensive, that would probably make it easier to add some mild-hybrid ability to an older car. Or that BAS-Hybrid setup used by GM.
