EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   DIY EV pusher trailer test on 1st generation 1999 Prius (NHW10) - with photos (https://ecomodder.com/forum/showthread.php/diy-ev-pusher-trailer-test-1st-generation-1999-a-22189.html)
EZP 545 06-07-2012 11:52 AM
2 Attachment(s)
Trialed an Estima rear pushing the Prius (turtle car) described as
Broooomstick.
On 48V using a Kelly controller and hallprobe shaft
commutation, this pushed the Prius at 20km/hr but limited starting
torque. For good starting torque a 3 phase synchronous type control is still
to be sorted. 144v would be needed to achieve 60km/hr.
http://ecomodder.com/forum/attachmen...1&d=1339084204
The Estima rear 18kw unit (Brooomstick) was being tested on the Prius, but it will be ultimately used as an electric power source for this Smartcar:
http://ecomodder.com/forum/attachmen...4&d=1339108725
MetroMPG 06-07-2012 11:58 AM
For those in North America not familiar (I wasn't!), the Estima is a hybrid minivan only sold in the Japanese market according to this article:
Toyota Estima Hybrid gets a full redesign
http://www.autoblog.com/media/2006/06/estimapurple.jpg
It featured a high-output rear motor on a differential to provide electric powered 4-whee-drive (in addition to its hybrid front-wheel-drive setup). Looks like that's what George used in his project.
MetroMPG 06-07-2012 02:16 PM
( Also see this other related project by George: http://ecomodder.com/forum/showthrea...ius-22193.html )
EZP 545 06-07-2012 06:40 PM
1 Attachment(s)
The Estima rear 18kw unit (Brooomstick) was being trialed as a electric power source for this Smartcar, Which had inappropriately immobilized itself from starting with an electronic keylock at the time, so I had put a Dunce's hat on it. Had to A frame it to a Merc Doctor to recode it!!!!
Present thoughts are to use 2X E-Tech motors, one on each rear wheel and leave IC drive as is, or the pusher trailer in some form.
pete c 06-20-2012 12:48 PM
What exactly is the point of an EV pusher trailer on a vehicle that is already capable of EV low mode at low speeds?
I guess it makes sense on a straight gasser for stop and go traffic jams.
I think a better concept is a generator trailer for use with a light, short range EV.
EVs are pricey now because 100 miles worth of battery pack is big $$$$.
I would think that a simple light EV with a 30 mile range could be made rather cheaply. The question is, how big a generator would be needed to power such a vehicle at 65 mph? Basically, make a Volt, but, the engine is in the trailer, not the car.
This means saved weight, which means less expensive battery. Why should you have to haul around a lump of an ICE when the majority of your driving is well within 30 miles round trip.
rmay635703 06-20-2012 01:16 PM
This means saved weight, which means less expensive battery. Why should you have to haul around a lump of an ICE when the majority of your driving is well within 30 miles round trip? So you can own a volt
The reason you would want a pusher genset on a hybrid is if you have a motor that is more fuel efficient under the load you require at 25mph than the existing motor inside.
MetroMPG 06-20-2012 05:05 PM
Have a look at post #4. The concept was being tested on the Prius, but ultimately intended to push a Smart car.
I think a better concept is a generator trailer for use with a light, short range EV. Basically, make a Volt, but, the engine is in the trailer, not the car.
Something like this? :)
EZP 545 06-20-2012 06:08 PM
The Pusher trailer was being trialed. The Prius already had 48V 100Ah extra batteries installed and is operating as a PHEV using an Enginer DC-DC converter which can suppliment around 4Kw enough for 36km/hr in EV while the batteries hold out.
It was easy to utilize the already battery enabled Prius to do the testing. The aim at that time was to use the Estima Electric motor, 6:1 gearing and differential assembly either to replace the IC in the smart Car, or to use as a Electric pusher in some way.
Yes I agree entirely with the suggestion that a small range EV with a method of extending the drive when required is a good concept, and Batteries are not only expensive, b ut if the battery cost is factored in as a forward price for your running costs, you are hard pressed to match a Prius C.
Idealism and Reality are in conflict at times.
George S
ron 07-04-2012 08:32 PM
looks like a good platform to hone your skills and solve alot of problems before you stuff it in a ride. I am interested in the insight concept unlike the prius it can be run on either ice or em . I think adding that type of motor to my techoma would give excellent results .
unheardofinstruments 07-04-2012 09:03 PM
Pusher trailer
I calculated 7.5kW to keep a light streamlined car (based my calculations on a Porsche 924 I am electrifying) traveling at 110kph on flat ground which is a pretty small gen-set. Hydraulic regen is planned for my range extender trailer/sleeper and a permanent magnet generator from a wind turbine is a very efficient generator which could also provide regenerative braking power. Ideally a lightweight small as possible aeroplane alternator (PMG and small gas turbine) would be the power source of choice or a hydrogen to electric cell but I will use a small lightweight 2-stroke rc plane motor. I would like to experiment with an exhaust heat generator to supplement the power output using thermal generators as about 50% of the wasted energy for an ICE is heat. I estimate at least 50% efficiency of converting the fuel energy to motion, rather than the 25-30% of a conventional car as it would be running at optimal rpm the whole time and be mainly a source of heat for power. The idea of a large infernal combustion engine and gearbox in the drive train of a hybrid seems silly to me as electric drive train is so much more efficient. Modern Hybrids have it the wrong way round. The weight saved using a small gen-set to keep the batteries near topped up would in turn require a lot less energy to roll. A cost comparison of replacing the complex and weighty ICE/gearbox in the Prius with a small generator and slightly chunkier electric motors would show it; too heavy to be efficient. There are a lot of small purely conventional cars that get a lot better fuel efficiency with no added complexity. Aerodynamics, lightweight materials, low rolling resistance tyres... no end of ways to improve the car. I don't see the big car makers really trying.
EZP 545 07-05-2012 07:47 PM
:rolleyes:How does the hydraulic regen operate?
I am considering using 360% variable Nu Vinci cycle hub as a method of varying the speed of an alternator , to enable controlled light braking as the vehicle speed reduces. It seems to me that the hub must be able to handle a persons weight standing on a pedal, so with apropriate gearing / ac clutch to disengage/ and 4:1 belt to the alternator, A variable load capable of regenerating braking may work. Say 2-3 kw of Braking load, which would be useful recovery.
ron 07-05-2012 08:43 PM
way back when, a wheel motor was used ,using the weight of the vehicle to drive hydraulic fluid that powers a generator to charge the batteries.
unheardofinstruments 07-05-2012 09:47 PM
Nu Vinci
planetary reduction gears with infinite ratio are currently used in the Prius and
here is a guy making one (already tried several ideas and he has some great stuff to lengthen the life of lead acid batteries and some promising battery research, motor plans etc too);
electrichubcap.creativesystemdesigns(dot)com
near the turn of the century this gems only use was hand driven rail cars
rexresearch.com/constran/1constran(dot)htm
George Constantinesco: Inertial Transmission (US Patent 1591471 etc)
so simple!
the oscillating weight matches the engine output
check it out.
unheardofinstruments 07-06-2012 01:32 PM
hydraulic regen
I was planning on an electrically activated clutch from an AC pump run off the brake light circuit to kick in the wheel driving fluid up against an accumulator, the small gear pump I have can act as motor using the stored pressure for takeoff using a small control lever/valve in the cockpit. I originally thought it would be good for a trailer but it has been done with higher efficiency as a drivetrain for a car before and patented too even variable torque/power has been done with a vane style pump with a warpable membrane that pumps variable volume. 80% efficiency has been done.
EZP 545 07-06-2012 05:51 PM
Regen braking recovery
nice scheme to use the variable swash plate to hold output speed as input drops. What effective variation in ratio can be achieved.? Cf the Nu vinci at 360%, which I guess can be considered as 1:1 up to 1:3.6
Thanks for interesting links re hubs and inertia drive. Looked good in Paris, wonder what happened to it?
ron 07-06-2012 09:22 PM
be careful using your pump for a motor , the shaft seal on a hyd motor requires a tank line so is wont blow out, a pump does not always have this feature and the shaft seal will let go
