DIY Freeze Plug Engine Block Heater Install, 1989 Corolla
I hunted around the web before I did this, but never found a tutorial showing a freeze-plug engine block heater installation on any car. (EDIT: I should say I didn't find any that I thought were more than a little bit helpful and/or pertinent.)
... probably because it isn't a common thing to do. If you live in the great cold north, your cars come new with OEM heaters, and if you don't, you presumably don't need one. I added a heater and did it the OEM way, and wrote a tutorial. http://ecomodder.com/forum/attachmen...1&d=1351895196 You can read all about it here: DIY How to Install a Block Heater, 1989 Corolla | Christofoo Review Of course the details depend a great deal on make/model. Let me know if you find it helpful. Cheers, Chris |
Just a tip about the copper exhaust gasket, watch the bolts carefully for the next 2-4 weeks. My camry got a new exhaust manifold back and that ended up being a problem area. It came loose enough to leak twice in 40k miles. My car has 3 bolts in that area, looks like yours is only 2.
Nice tut, I might have to do this someday. What kind of costs did you run into for this? |
Heater: $40 IIRC ($18 for Kats brand online) Manifold gasket: $19 Exhaust pipe gasket: $3 So it could be as little as $21 (+tax) if you get Kats and take a chance and skip the manifold gasket. My grand total was $62. I had all the tools handy. Assuming you don't have the warm-air-intake like my 4A-F (and everything else is the same) I would consider leaving the manifold in place for the operation. (But don't be too surprised if it doesn't pan out.) |
