DIY Hybrid-ing old cars with low budget, is it possible?
Hello everybody!
After a period with some problems with my old Renault, seems that she's finally working the way it should be. So I'm having a lot of strange ideas in my mind. The car runs good but it's not very efficent, the tyres are quite small (145 or 135/80 r13) and the car is lightweight (700kg) but the engine is really old and it doesen't help to improve mileage (15 km/l). I was wondering if it's possible to realize some kind of hybridization of an old car like that, with plenty of space under the bonnet and in the trunk. I'd like to get my hands dirty in a summer project, something not too extreme. I saw hub brushless motors, drum brushless motors, but it's quite hard to have a clear idea of the situation. I think low powers (less than 10 HP) are enough for a car that, brand new, had 34 HP! https://scontent-mxp1-1.xx.fbcdn.net...49&oe=580B4F04 |
Its quite possible. It also not easy and quite complex. Definitely much more extreme than most here have tried.
I'd put a Fiat Twinair in it and call it a day. With only 700kg to push it would be a riot and the low loads would make it very economical, at least at lower speeds. 3l/100km shouldn't be hard.
The R4 is manual I presume? Adding hybrid is tricky because you have to work out how to actually control it during gearshifts. If you just do something like an E boost button that might be easy but you'll loose some of the benefits. It would probably be best to just go to full EV, as even small motors will probably provide more power than you have now. |
My understanding of mild hybrids is that most of the savings come from being able to downsize the engine, which you're obviously not going to be doing by bolting on an electric motor to the existing engine. You'll be able to recover a little bit of energy that would otherwise be lost doing braking, but it might not even offset the additional weight of the batteries.
Seconded on the pure EV approach; but if you want to do something and not screw up a nice car, consider a pusher trailer.
Get a good Lombardini diesel and drop that in. That would be easiest. You would just have to come up with an adapter to attach the engine to the existing transmission, but lots of people have done stuff like that already.
I like the idea of adding hybrid capability to the car but for the shadetree mechanic it would be really difficult - you would need to create and install a completely new drivetrain, either to replace your existing one or else to replace your undriven axle. The latter would actually be easier, I think. But going this route would add a lot of weight to a car that doesn't have a lot of capacity in the first place. Another concept would be a series hybrid. This would also completely replace your existing drivetrain. An electric motor would become your prime mover. You would have batteries to provide surge power when needed, but there would also be an engine powering a generator. Ideally the engine would be just powerful enough to provide slightly more power than the vehicle needed at a steady cruising speed, which gives the designer the opportunity to install a smaller engine and run it closer to its most efficient speed. The slightly excess capacity and regeneration would provide the extra power needed (stored in the small battery pack) for acceleration, hills etc. Not many go this route. I first read about it in Mother Earth News in the 70s; Mother then tried it on their own a couple of years later and reported that it did okay. But it's a squeeze getting all that non-optimized hardware under the hood. Hmm. I wonder what the dimensions of the Prius C's drivetrain are, and how well you could fit something like that under the hood of your battered old 4. That would buy you all manner of hybrid capability, ready-made. |
Your best and quickest payoff would come from extreme hypermiling where possible. All the other options would likely never pay for themselves.
I think the path of least resistance if often the best one to take; many of us suffer from delusions of grandeur in our ability- technical or motivational- to complete such a project (noodling it and starting it is the easy part).
It would also help to evaluate your usage patterns- lots of city and mixed city/rural driving is where hybrid tech really shines; mostly highway cruising like I have wouldn't pay off. Is the stock engine worn out? What would the car's economy be with a stock overhaul or even lightly modified like "RV cam", hot ignition, and the like. Next step up in effort and expense is an engine swap. There are loads of more modern, more efficient engines to choose from. Maybe swapping in a modern 5 speed transmission along with a new engine would be the way to go. I can see a 3-cyl/5sp m/t Swift drivetrain moving that car right along while being efficient. Or add an electric motor. EMer Brucey did but he didn't rave about the results. His was a helper, used on acceleration. I'd do a standalone, divorced from the ICE. P.S. Doing the EV part is possible on a small budget. Study up on MetroMPG's EV projects. |
Unfortunately it's quite hard to put a different drivetrain inside that car, it has a strange layout with longitudinal middle front mounted engine with gearbox in front of it, and to be honest i'd like to try something less "extreme". If I'm going to change the engine, I'd go for a full electric conversion.
Obviously an improvement of the engine with electronic ignition and maybe injection and of the car structure in order to rise the efficency are in the list. The car is four speed manual, there is also a compatible auto transmission from the R5 automatic, but I think it's really terrible. The use of the car isn't intensive, I can use and I use other modern cars, that's my toy that I can use whenever I want, it's practical, simple and it's not bad also as a daily drive. I wrote here to know your opinion and look if someone tried something similar before. |
When I was first planning my Firebrid project, I considered dropping in the mild hybrid powertrain out of a Chevy Tahoe. However, a closer examination of that system demonstrated to me that the ease of installation of that system into the Firebird did not justify the marginal increase in mileage that would be realized. Soon after I determined this I also discovered how bad the floors and mechanicals were in the convertible, pointing me in the direction my project is now taking.(I also like the challenge my project presents.)
If you are looking for easy and lower cost, go the EV route. Bill the Engineer |
Have you considered the Toyota MGR? It weighs ~100lb and puts out 68hp. That's 50 somethings in metric. :confused:
It would replace the transaxle and maybe half the batteries could go where the engine is. I have one, but there are SUVs coming to market in 2017 that have a rear axle with twin motors and an electric differential, which enables torque vectoring. I'm no longer a fan of open differentials, since that incident on the black ice. The good news about the Toyota part is that Paul M. Holmes' open source controller is characterized to work with it. It's called Open Revolt, so you can drive around with that in big letters in the back window. :thumbup: |
If you could manage to work around a homemade BAS-Hybrid setup to add some mild-hybrid capabilities to your car, that would probably be the lowest budget possible hybrid approach.
Easiest way to do it is get an old diesel car and stick a turbocharger on it.
Turbodiesel is the original hybrid. |
I'm with the TD crowd. Old VW Golf, original diesel (install new head bolts!), add a turbo. Done.
Or follow a similar pattern on pretty much any older econobox. With just a little bit of know-how the older VW diesels are reliable, not powerful by any stretch but ridiculously thrifty. Add the turbo to fix the power detriment while retaining the long legs the rest of the time. I think hybrids are cool and all, but this approach retains all automotive-grade hardware and is more or less serviceable by any other mechanic. |
If you could find a suitable Diesel engine to swap into the R4, go for it. Anyway, since you're Italian and so are most of the gaseous fuel system suppliers, it's actually surprising that you didn't even mentioned either CNG or LPG as options.
I've given thought to this idea. I think a good way to do it would be to add a small electric rear drive to a small fwd manual trans car. Use a MT car because it can be placed in neutral to run in EV only mode. Also make it manual steering/brakes. Use the rear ends out of any small old 4x4 such as the old honda wagons along with a simple, small fork lift motor. Not sure if this would do much in the regen area, but it would greatly improve efficiency in stop and go urban commutes. I would really like to see such a system added to a first gen insight that could be tied into the battery pack. I would make such a system very light weight with no more than a 10 hp motor. It would be strictly for EV only stop and go/low speed driving. Stop and go is where the first gen insight fails due to its inability to move without its ICE. I think honda should have looked into adding another clutch on the other side of its motor to allow an EV only mode.
Single speed electric drivetrains have an overall ratio of 6.78:1 (Toyota MGR) or 9:1 (Tesla). Your 4x4 differential will be ~3:1. Without a transmission it will suffer at low speeds.
Or a belt drive.
