DIY OBDII to ScanGaugeII cable
I was tired of switching my SGII cable between cars now and then, especially since it's routed behind the console in the Elantra. So, I had a male ODBII connector (J1962) lying around from a dead vag-com ebay cable (VW specific diagnostic tool) and decided to make a 2nd SGII cable for cheap.
Here's the mapping between a standard CAT5 network cable and the J1962 connector Brown - Pin 16 White/brown - Pin 15 White/orange - Pin 14 White/blue - Pin 10 Orange - Pin 7 Green - Pin 6 White/green - Pin 4 and 5 Blue - Pin 2 Facing the connector with the wide side up, pin 1 is in the upper right corner. You could even make a SGII cable for next to nothing. If you don't have the male connector at hand you could use a junkyard female connector, extend some flattened pins made out of solid conductor power wire and tape it with the other male connector in your car. |
This is good info.
I'm fuzzy on your last suggestion about using the junkyard male connector. Could you elaborate? |
I edited my post. I had the male/female part backwards. Here's a pic I snatched from a pdf of someone who made a female connector. The SGII compatible cable will need more pins though.
http://img380.imageshack.us/img380/7...nnectoryb7.jpg |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
