DIY PDR aka Dent Removal
Help
I have never used a (PDR) paintless dent removal tool/kit or seen one in action. Dent removal aka PDR tool choices 1.slide pull with glue gun aka new slide pull that does not pierce metal (ebay) 2. dent out kit / dent fix kit (amazon) Besides using web based purchase choice can these tools be had locally. I have a vehicle with roof , hood, etc hail damage. |
I have used the services of one of the local Paintless Dent Removal (PDR) places. They use a heat gun to soften the paint, to reduce the chances of it cracking and flaking away. They will generally go in behind the dent and push it out from the inside, using a "bodyman's spoon" or another pushing implement. Sometimes they push out more than they need, and have to recess some part of the former dent again.
It seems to be a real art form to me. I have significant doubts that you would get good results from the glue gun approach, and I would be astonished if you could even get something that looked good at 50 MPH from 50 feet away (a "fifty-fifty job") by using one of the suction cup thingies. -soD |
http://http://www.hsautoshot.com/EngIndex.html |
The suction cup method can work well on semi large shallow dents like from some one sitting on your hood.
There is a heat gun, dry ice/duster method that supposedly has good results on some dents. I have not tried that method yet but hope to try it on my dads car later this year. That method you heat the dented area well with out burning the paint and place the cold source on the hot metal the difference in temps causes the dent to pop out. Search on google before performing it though. |
I tried "POP A DENT" the glue never attach/bond tight and so when you tight the tool just pulls small tabs of leaving messy glob of glue. |
Heat guns can be bad I once bubbled/crackled the paint on a car at the dealership I worked at when removing a different dealers sticker. Luckily the car was an old used car that was priced at $5000 to sell. Not to bad a record though with removing over 100 stickers from cars and only slightly damaging the paint on 1.
The trick to keeping that from happening is do not stop moving the heat gun and do not heat small sections at a time, but I'm not sure how that works with the method above as I have not tried it. If I get around to trying it I will have to do an instructable on it. |
Buy a Daewoo (aka Asian Chevvy). Last time I had one of those fixed for dents the guy just pushed them out with his thumb.
Phantom - for cases like that, try a hair dryer first, then move up to the heat gun if it isn't enough. It doesn't get as hot as a typical heat gun, so it's less likely to damage paint or other surfaces.
Heat/cold dent removal
I have a bunch of small hail type dents in the roof of my metro. I tried a variation on the hot/cold thermal shock dent removal method a month or so ago. Waited for a 102 degree day with my dark blue car parked out in direct sunlight. I believe I could have fried an egg on the roof. I placed several small rubber collars about 2 inches deep over several hail dents. Since I had access to it, I took a thermos full of Liquid nitrogen and filled each collar. It took a minute or two for the N2 to vaporize from each collar and as it was doing so I could hear the metal popping and booming. I repeated the treatment a few hours later after the sun had reheated the metal. Sadly, I could'nt see any reduction in the depth of these small dents.
