DIY plastic domes
3 Attachment(s)
I decided to try to make plastic domes by gluing a cd-cover to the open end of a tin can and sucking out the air through a check valve, after which i heated the plastic with a heat gun.
My conclusion is that i need to use a larger diameter can and get better at heating evenly with the gun. I plan on covering my non aerodynamic foglights with these. |
Interesting, but I'm having a hard time visualizing them on a car. Got a pic of yours? My first thought is just to use the flat plastic piece and leave it at that.
Cut out the bump, put it on the front of a flat fog-light. At least, that's the impression that I am getting.
It must be the teenager that still lives in my head, but that third pic looks.... mammalian. :D -soD |
Well that "tit" you see in the picture isn't the final version that goes on the car, i only plan on curving them a little, because the bumper is very strongly rounded at the fog lights and the damn things stick out a little bit, so that a flat piece won't fit.
with a plastic CD cover, I would be worried about it cracking when it gets hit with a rock. I have had more than one CD cover break due to flexing.
Your project is right along the lines that I have considered tackling. Please keep up the good work.
old... |
you just need a mold, that is all.
http://www.youtube.com/watch?v=WL-h0HAcdFA |
Very creative :)
A friend of mine once worked at a plastics company Link below. If the heat doesn't work out to your satisfaction they have clear balls that could be cut in half to fit your needs... I prefer the bragging rights of the DIY o good luck to ya. BALLS PLASTIC BALLS FROM COMPLEX PLASTICS 1-888-PLASTIK 1-800-363-2870 SUPPLIERS OF INDUSTRIAL PLASTICS |
I'm not overly concerned about rocks, partly because the raw material is free. (in fact, it's better than free because it reduces garbage)
