EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   DIY: Push Button Start (https://ecomodder.com/forum/showthread.php/diy-push-button-start-51.html)
SVOboy 11-17-2007 12:14 PM
Everyone envies the person with the push button start. Perhaps it's that cool cat with the S2000 or the fuel miser with the hybrid, but they envy is still there. With this write up I intend to show everyone how easy it is to add this to your own vehicle. This was done using CRX wiring, but with a simple check of wiring this can be duplicated for almost any vehicle. If you do this don't forget to send me a picture of you setup!
Purpose: There's the bling factor of having a push button start (especially if you use the s2000 "engine start" button, the anti-theft factor if you wish to hide the button, and the convenience factor of having the button near the shifter if you are using it during engine off coasting.
Time: 1 hour
Tools:
- Soldering Iron
- Wire Stripper/Crimper
- Screw Driver
Supplies:
- 1 SPDT (Single Pole Double Throw) Relay - 3.99 at my parts store
- Some female quick connect ends - 2.99 at the parts store
- Wire
- Solder
- The button!
Check out this schematic and look at your SPDT relay, pretty simple. Figure out which wires are which and wire the stuff up. I labeled this with the colors that are actually used in my CRX. This write up is applicable to almost any car, but you'll need to figure out which wires are which if you want to do this to another car. Pretty simple. Most people use the S2000 start button, but you can use any button that is normally open and only connects when pressed.
http://crxmpg.com/edrive-images-crxm...uttonstart.jpg
And here's a picture of the S2000 button, just for reference:
http://www.burtmanindustries.com/s20...tart_close.jpg
Wire the stuff in there not too prettily just to make sure it works. Here's mine half done:
http://crxmpg.com/edrive-images-crxmpg-com/DSC00066.JPG
Another shot with indications and all that on it.
http://crxmpg.com/edrive-images-crxmpg-com/DSC00068.JPG
Get your button and figure out how to mount it. I am going the way of small button skirted by washer and then mounted in my cigarette lighter hole. Here's the washer pre mounting and painting. I hot glued and burnt myself quite a bit, be careful.
http://crxmpg.com/edrive-images-crxmpg-com/DSC00069.JPG
I put this little cone over the button to paint the washer.
http://crxmpg.com/edrive-images-crxmpg-com/DSC00071.JPG
Painted shots, looks decent to me:
http://crxmpg.com/edrive-images-crxmpg-com/DSC00076.JPG
Wrap your crippled, burning hand in wet stuff:
http://crxmpg.com/edrive-images-crxmpg-com/DSC00077.JPG
Mount up the button itself into the center console part.
http://crxmpg.com/edrive-images-crxmpg-com/DSC00078.JPG
Finished the install with the new button, check it out:
http://crxmpg.com/edrive-images-crxmpg-com/DSC00079.JPG
http://crxmpg.com/edrive-images-crxmpg-com/DSC00080.JPG
Here's a final shot having actually put the interior back in my car:
http://crxmpg.com/edrive-images-crxmpg-com/DSC00095.JPG
I'm very happy with it, piece of cake, as well.
SSGPOHLMAN 12-12-2007 01:03 PM
so how do you go around your steering lock with no key?
trebuchet03 12-12-2007 01:07 PM
^^ You still need the key -- but the button makes restarting a button push :)
SVOboy 12-12-2007 05:47 PM
True enough! I mainly did it for the bling factor, even though I didn't end up shelling out for a prius/s2000 pushbutton.
Funny 11-13-2008 01:05 PM
Must subscribe, I keep losing this thread and forgetting about it.
SVOboy 11-13-2008 02:05 PM
It's not that hard to just do and be done with, :)
MazdaMatt 11-13-2008 02:43 PM
SVO, if you want extra ecomodder bling factor, put a normally closed push button in series with your ignition line. Push that and your car shuts off, push the other one and it start up again.
alohaspirit 06-07-2009 10:16 PM
good thread
is it possible to repost the pics again?
Allch Chcar 06-20-2009 06:19 PM
So how does the button change the actual operation of starting the engine? Is it on-off or do you still use the key for that?
This is new to me and I'm not sure I understand how you wired it up. Is it just for activating the starter?
QuickLTD 06-20-2009 07:10 PM
You turn the key to the "on" position then push the button instead of turning the key one notch farther to the "start" position.
SVOboy 06-20-2009 10:39 PM
I will try to find the pictures somewhere, they spent a good deal of time bouncing around too many servers. :p
SwamiSalami 10-16-2011 08:00 PM
I really like this concept. I want to know more.
rmay635703 10-17-2011 01:13 PM
Hmm, now if you can convert this engine start button to an injector kill button, I would be interested.
Leave it labled start and you still have the bling factor but instead end up with a more usefull button.
Nerys 11-06-2011 07:59 PM
what I want is the wireless enable. IE an RFID dongle so once your "in" the car the RFID dongle in your pocket or around your neck would "enable" the car then you just push to start.
the key would bypass all this so if you let someone else drive you don't have to give them your dongle.
Piwoslaw 11-07-2011 07:50 AM
Go one step further and have the RFID unlock certain functions/settings, something like a valet key. Without the RFID the start/kill switches (and any other ecomodder gizmos) would not work, so only the ignition could be used. And maybe the max speed could be limited?
deathtrain 11-12-2011 02:30 AM
that would take a rocker switch. for the sake of things. push left for the kill switch and then push right for the starter.
rmay635703 11-15-2011 01:10 PM
Nah, I would just need it to kill the engine not start it, we were only going for looks anyway, its not like it would actually need to start since I wouldn't use that feature.
dirtydave 07-09-2014 05:20 PM
I know this is an old post but do you still have the pictures? all the links are broken :(
user removed 07-09-2014 06:26 PM
My 37 Ford had a push button starter. I used it to prelube the engine before turning the ignition on. Best for a car that sits for weeks at a time. It also had a steering column lock.
Factory built.
regards
Mech
serialk11r 07-10-2014 03:35 AM
I feel like engine start buttons aren't really good for this, but how about a race-car style toggle switch for the injectors instead of the fuel pump? :D Even more bling!
Chrome Red Toggle Switch Cover Guard
dirtydave 07-10-2014 09:43 AM
Yeah trying to hook this up in my KIA
