Old 10-30-2009, 09:15 PM   #1 (permalink)
EcoModder!
ratatouli - '01 honda insight
88 Crx - VTi swap
Planning to do a VX swap into my 88 crx hf. I need some help figuring out what all to get together before I order the motor. I have a vx under dash harness ( don't know if I need this) and ordered a US P07 ecu. Will this ecu work with the JDM d15b vtec-e( I think it will)? Also I am wondering whether I should source the engine from vtec-motors (canada) on ebay or nippon-motors? Should I buy new motor mounts for the old engine or the new one? I know I'll need an oxygen sensor. My hf already has an egr do I need a different control box? Do I need an obd0-obd1 harness for the ecu. I'm a little lost on the specifics that most build journals seem to skip over.
Thanks for any help.
Last edited by 88hf; 11-10-2009 at 06:45 PM.. Reason: change thread name 88 Crx - VX swap > 88 Crx - VTi swap
Old 10-30-2009, 09:18 PM   #2 (permalink)
EcoModder!
Is the d15z1 the same as d15b vtec-e both are supposedly sourced from japan.
Old 11-02-2009, 09:53 AM   #3 (permalink)
EcoModder!
List***
clutch
engine mounts (old ones dry-rotted)
cv axles (reusing hf transmission)
axle oil seals
engine seals
p07 49 state ecu (on the way)
obd0-obd1 ecu harness
water pump (is this the same on d15b vtec-e and d15z1?)
timing belt (is this the same on d15b vtec-e and d15z1?)
5-wire 02 sensor for lean burn
Old 11-03-2009, 05:53 PM   #4 (permalink)
EcoModder!
will this work for most of the electrical conversion with the new ecu?
: 88-91 Honda civic crx Mpfi Obd0 to Obd1 conversion kit:eBay Motors (item 190345563288 end time Nov-05-09 17:26:53 PST)
can I use my old cluster or will I need a civic vx cluster?
Old 11-03-2009, 07:15 PM   #5 (permalink)
EcoModder!
Ok, I changed my mind. I'm going to get a d15z7 (d15b) 3 stage vtec and do some obd2 wiring! Means I just wasted money on a P07 ecu. Oh well.
Old 11-05-2009, 11:20 PM   #6 (permalink)
recession proof rebel
k.civic.f4i's Avatar
man..... no love at all? wtf guys? if you can find it, grab the z1 motor. here's a link to someone else who did it....crxMPG - Gas mileage never looked so good CRX D15Z1 (Civic VX) Fuel Economy Swap Guide
if i had the money that's probably the project i'd be working on. but since i dont i'll just modify what i have. you should too... aero at least.
don't be discouraged. just keep on pushing
The Following User Says Thank You to k.civic.f4i For This Useful Post:
88hf (11-10-2009)
Old 11-08-2009, 01:26 AM   #7 (permalink)
EcoModder!
Purchased d15b 3 stage vtec
Motor, 5 speed tranny, ecu and engine harness $1284 shipped. I'm doing the swap!
Old 11-09-2009, 08:20 PM   #8 (permalink)
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
When you get all done, would you post what your before/after mileage looks like. Power wise, it should be a lot quicker. Mileage wise, I suspect it will be a lot closer to what your getting now, than not. I think it will be good change, overall. The car should be a lot more fun to drive, also
Old 11-10-2009, 01:48 AM   #9 (permalink)
EcoModder!
I expect mileage wise will be a lot better as well. Sure the old engine gives the occasional 55-60mpg roadtrip, but in town it gets about 30-35, and to maintain high-mileage is currently excruciating. I'm planning on doing an alternator kill switch too, and hopefully get one of these new-fangled mpguinos. I have two of the old supermids, but it would be nice to get mpg readout and my old(current) vss was giving me bad readings in the hf which ultimately led me to stop using them. My best mileage in the crx seemed to be about 35mph in 4th gear according to the supermid... I'm expecting my best constant mileage speed to increase a bit. I've read that in the civic vti 30km/l (72mpg) was possible at 60km/h (37mph). The hf is several hundred pounds lighter, has longer gears and better Cd.
When I pull the old 155K motor I'll rebuild it and put it in my 90 crx that has 270K mi for a real comparison against the conversion. Although the 90 is heavier.
Old 11-28-2009, 06:24 AM   #10 (permalink)
discovery's Avatar
How far in the project are you now?
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
VX final drive swap: Who to believe? Cleft_Asunder EcoModding Central 28 01-28-2009 09:17 PM
have some questions about a vx or hx swap soj8888 EcoModding Central 3 07-24-2008 11:54 PM
CRX HF transmission swap paulwelkins EcoModding Central 2 02-02-2008 05:52 AM
