DIY Water for Gas kit (spam)
The ‘Do-It-Yourself’ Water for Gas Kit produces a HHO gas or Brown’s Gas by the process of electrolysis of the water, which then combines with the gasoline and boosts up the performance of the vehicle.
See the Wikipedia entry for 'Brown's gas' - section 3.5 "Junk science and fraud".
The eternal contest: the immutable laws of physics vs. a sucker born every minute. Suzanne, you trying to sell this wonder widget by any chance? |
Is it conclsitered bad form for me to lead "suzanne" on and say I want a "magic" gas gizmo just for the insueing carnage?
Send her a PM. I'm sure she'll be thrilled.
"She" tried to spam the living **** outta GS already...
they're all gone now. "She" probably didn't like my PM either... |
Is it reported?
Ban her and kill this thread. Next, please. |
zoltanbod: can you provide more details about that prize?
I was going to kill this thread, but I'd like to know more. Sounds similar to a prize I learned about recently that's directed at "clairvoyants". |
...no paper or electronic submissions allowed (wink,wink)! |
NachtRitter: that's the one!
zoltanbod: thanks for that link. I love the concept. Put up (scientifically verifiable by a 3rd party), or shut up! :) |
Any HHO system waists energy, anyone who with a high school diploma should recognize this right off. The way it helps is by improving the burn of fuel mist, the same way supplemental propane injection works. In fact supplemental propane injection (SPI) is a excellent example for this. With SPI you use you're normal fuel, you just add a little propane. This improves FE even if you factor in the BTU's of the propane you use. The idea is to burn more fuel in the cylinder, and send less of it to the cat. With HHO you make the supplemental fuel. So, with a typical set up on a small to mid sized car you'll be using about 1/2hp off your alternator. The alternator has about a 15% loss, a really good HHO cell has a loss of about 20% (i would guess a water for gas cell has about a 90% loss), and then you put it into an engine that has a loss of about 80%. So the aim to make your own fuel dumb, it's just to improve the burn. People have found that with HHO they can get away with a leaner mix, which is where some improvements come from. Though a water mister may work just as well. I don't use HHO on my car, yet. I use acetone as a fuel additive which gives similar gains (very minimal 3-6%) from the same inefficiency. |
HHO is a scam, and I won't believe otherwise until I read about it in a scientific journal or see it installed as original equipment by a major automaker. |
Dr. Jerryrigger -
CarloSW2 |
Not all alternators are equal, some are 85% efficient, and I stated the ICE as 80% loss, and you at 70% so things balance out a little there. |
The hokey devices I've seen make and use the hydrogen/oxygen gas at once, rather than splitting the water during low load and making use of the stored energy (the split H2 and O2 gas) during high load. The only way to make a true hybrid system would be to control it so that it was only using electricity to make and store the gasses (in separate tanks!) the same way that kenetic energy is returned to the battery of an EV- during coasting, downhill cruising, braking, etc. THEN when the engine is loaded up (highway merging, hill climbing, etc.) the gasses are conservatively metered into the engine. Since you've taken a car that normally had to be fueled up with one fuel (gasoline) and made it into a car that needs to be filled up with two fuels (gasoline and water) you've made a system that is undesirably more complex for the average user. |
The thing with HHO and O2 is a little questionable. I've never found a satisfying answer to; what is really going on. Theoretically you have enough H to make a complete burn of the HHO so it shouldn't change anything. Also if your'e really burning fuel that would normally burn in the cat, than you should see less O2. I've heard people claim that the O2 sensor reads the H2O as O2, but I can fined no mention of this from water injection guys, so I'm pretty sure this is bogus (also the amount of H2O in normal exhaust makes this one rather questionable) I think the real issue it that you can get away with a leaner burn with HHO, and that is where you see real FE improvements. |
Does anybody here think this is possible?
What's possible? Being fined for HHO, or creating efficiency from inefficiency, or perhaps just being waisted? :rolleyes:
A lot of HHO cells (the crappy ones like W4G) are much better steam machines that HHO generators. And some HHO enthusiasts are thinking that some of the gains are from the steam. Steam is cheap in an ICE, why make it off the alternator when you have the 800F exhaust sitting there? Frank Lee, at the moment I'm am living proof it's possible... .... possible to be wasted :p (I wish there was a more drunk looking emoticon than that, so pretend that guy is a little more red, only has one eye closed, and that's half a sandwich found on the sidewalk hanging out of his mouth) |
Was it Kool Aid? :confused:
no, I think it was that half a sandwich I found on the sidewalk.
half an agave worm?
Very minimal gains with HHO
I used to own a 2003 Kia Sorento with it's 3.5 V6. It was a gas hog. When gas went up to almost $5.00 per gallon I had to do something. I tried a HHO system. I purchased the system from a group known as backyard builders of tampa. The system was nice and was not cheap looking. I installed it and it seemed to work. I put a lighter on the tube and the flame would get a little bigger and then pop. On the Kia I saw very little improvement in mpg. The customer service of backyard builder was great. I was on the phone with them constantly and they would give me different things to try to make the system more efficent. We did a pump for the flow of the H2O and these electrical components on the o2 sensors. The mpg on the Kia improved a little more but it finally got to the point where the only way to get anymore out of the system was to have software for the car's computer made to cut back on the fuel supply from the injectors dramatically.
HHO systems do work, but very minimally. It would be cool to put one on a hybrid vehicle. |
MannyV,
do you know any specs on the cell? (liters per min, watts/amps) and how much is "a little mileage"? |
