02-06-2014, 01:28 PM
Master Ecomadman
syncro-mesh (how it works - youtube)
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
02-06-2014, 02:14 PM
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by arcosine
How a transmission works
Maybe back in the 50s. Sliding gear transmissions have not been used since. In modern transmissions, the gears stay stationary and collars slide on the output shaft:
The Following 2 Users Say Thank You to mechman600 For This Useful Post:
02-06-2014, 07:35 PM
Master Ecomadman
1936, I was looking for an example od a non-sycromesh transmission, like the reverse gear in your picture. Are then splines that the reverse gear slide on integral with the outout shaft?
- Tony
02-06-2014, 07:39 PM
So much for an intelligent conversation about the lubricant thats safe for yellow metals.
02-06-2014, 07:42 PM
That's a crash box (first post).
regards
Mech
02-06-2014, 07:48 PM
Master Ecomadman
- Tony
02-06-2014, 07:49 PM
I prefer spinning hydraullic rams.
regards
Mech
02-06-2014, 08:40 PM
Meshing all gears all of the time seems inefficient. Perhaps they aren't loaded so the friction is greatly reduced?
These videos remind me of how a differential works.
02-06-2014, 08:49 PM
#9 (permalink)
That's correct--there isn't a whole lot of friction because the gears are all spinning on roller bearings. Some power is lost just keeping everything moving, of course, but it's not as much as you might think from seeing that everything is always meshed.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
02-06-2014, 09:43 PM
#10 (permalink)
Yeah, its easier to move spinning gears and to get them to mesh with others vs having them at a standing still. Thats assuming you are using gears in the first place.
