Dodge RAM 3500 quadcab dually converted
1 Attachment(s)
2005 silver Dodge RAM 3500 truck, 5.9L Cummins diesel/converted to also run on straight vegetable oil (SVO), dual rear wheels, quad cab, long bed. Installed Greasecar computer controlled veggie oil system with 40 gallon veggie oil aluminum fuel tank. Extras: AM/FM/CD, alarm system, door column mounted triple pod gauges (veggie oil fuel pressure, Turbo thrust, transmission temp), AMSOIL engine oil bypass filter system for improved engine oil filtration, Line-X spray-in bed liner, Truxedo tonneau bed cover. Exterior and interior in great condition, 200,000 miles, A/C and heat work great, new tires on front. Recently replaced all major fluids to high efficiency AMSOIL synthetics (transmission, crankcase, differentials, engine oil). $29,500. Will even throw in a full tank of SVO, plus 25 gallons of super clean veggie oil for the road. :D Located in SE Iowa. This is a truly great truck! Listing in several places, don't expect this to sit around long, if interested, don't wait.
