Does air in radiator increase warm up time?
I'm hearing splashing in my dashboard like heater core is clogged but it is not. Just wondering if I can burp the air out, will it heat up faster in the morning?
smmgoal.com |
Don't drive your car untill you managed to get that fixed or you might damage your engine. |
Else it might be rain-water in the ventilation system. Does it rain in Istanbul?
Also, welcome to Ecomodder. |
Air in radiator may increase the likelihood of a vapour-lock within the cooling system, with an increased risk of burning the head gasket and eventually bending the cylinder head.
Lol you all are responding to this like it's a real question when they included a non functional link to a digital marketing agency right in their first and only post.
Some of the best threads have been abandoned by their OP, it sorta frees up the discussion. |
hearing
2) I experienced this with a friend's package window air conditioner unit. 3) the buyer was required to drill out a factory located drain hole, which they failed to do. 4) If you have high humidity and flying insects that like to build nests inside machinery, it could explain what's happening. |
