Does Anti-Seize Compound Work?
Project Farm youtube channel has some cool tests they do. This time its all about how well anti-seize works on bolts as well as corrosion resistance. He even accounts for rust and heat in his testing.
They compared: Loctite Copper Permatex Aluminum Nickel-Graf Lubri-Matic High temp grease Fluid Film Candlewax Just don't use it as a motor oil... (duh). :D https://www.youtube.com/watch?v=Kj-kmIbSQvk |
I just watched this last night (and fell asleep before it got very far). Such a coincidence (or maybe not).
So, ...Permatex or Loctite (especially Loctite).
Yeah I antiseize or grease everything I put back together.
I have always used copper and high temp grease. |
We experimented at Huge aircrash back in that '70s with torque to pressure and got not repeatable results until the bolts were lubed. Anti sieze wasn't common except for copper sulfate, but most either prevented dissimilar corrosion fretting or provided a lube effect.
My suspicion is your bolt was over torqued and it's head failed after granular corrosion. |
yes. If vibration or other cycling forces are going to loosen the bolt, the anti sieze won't change that.
As long as you torque any bolt properly it will never back out. That being said, I always just hand tighten almost everything. Head bolts and bearing caps are the few exceptions. With both of those taken into account, I've used anti-seize for years and never had an issue of bolts backing out.
