Old 10-02-2015, 11:17 PM   #1 (permalink)
...beats walking...
EPA paper estimate dyno Road Load pwr
Found this old (1977) EPA paper:
http://nepis.epa.gov/Exe/ZyPDF.cgi/9...y=9100WXMP.PDF
Last edited by gone-ot; 10-03-2015 at 06:43 PM.. Reason: direct link to *.PDF file
The Following User Says Thank You to gone-ot For This Useful Post:
aerohead (10-03-2015)
Old 10-03-2015, 01:55 PM   #2 (permalink)
paper
I printed off the whole thing for the home library.Thanks much!
Old 10-03-2015, 04:01 PM   #3 (permalink)
...beats walking...
I saved a copy to HDD...I really liked all the references back to actual vehicles...and, this equation estimating "dyno" RLHP at 50 mph:
HP ≈ 0.253*(WT)^(0.456)
Old 10-03-2015, 04:43 PM   #4 (permalink)
actual
Yeah,and we get vehicle weight,how they did the rolling resistance,frontal areas,and drag coefficients to play with and compare to other sources if available.
Old 10-03-2015, 06:04 PM   #5 (permalink)
I tried to search on 'VW' and 'Volkswagen' but the page started jumping up and down and then a pop-up asked if I wanted to answer a survey, so I closed the page.
Old 10-03-2015, 06:41 PM   #6 (permalink)
...beats walking...
It's under: EPA home / NSCEP / Document Display...but try this direct *.PDF link:
freebeard (10-04-2015)
Old 10-05-2015, 03:45 PM   #7 (permalink)
specs
Originally Posted by Old Tele man View Post
Hey, aerohead, take a look at this e-book containing some of my "background" automotive research (HP not aero, however) work.
https://books.google.com/books?id=e9...r&pg=GBS.PA165
Wow! That took some dedication to put that all together.I'll bet that Rick is very appreciative of his 'network' for the data.I'd be pleased if my work was gonna help a bunch of gearheads with their projects.Good goin'!
Old 10-05-2015, 03:57 PM   #8 (permalink)
EPA Cds
I went over the entire paper Sunday.I'm glad for the frontal areas,as they were provided by the manufacturers.
The actual road loads were given from EPA coastdown testing and seem realistic.
Some of the Cds I've never had,but of the ones I do have,compared to the EPA estimated Cds,the EPA's are high.
An example would be Corvette,which EPA assigns Cd 0.70,vs Cd 0.50,from GM.
As time permits,I'll do more comparisons.
freebeard (10-05-2015)
