Does dirty fuel filter cause bad economy?
Hello.
I have read on various forums that people have experienced better fuel economy after changing their fuel filters. I'm wondering, how can a dirty fuel filter cause the vehicle to use more fuel? wouldn't it use less? Thanks. |
It can cause you to have worse, but most of the time it doesn't. (at least in my case)
Thanks,
I'm wondering though, what is the technical explanation behind it causing bad fuel economy. |
If the filter is clogged, it won't run. If it's restricted, it simply makes the pump work harder.
A dirty fuel filter makes no difference to economy but it usually restricts the upper rev limit simply due to lack of flow. Totally blocked the filter simply stops the engine since fuel can't get through. Pete. |
By trying to keep the engine running, the natural impulse is to add more throttle. So to make up for the restriction we try to add more fuel by pumping the accel pedal. So for instance instead of having the engine cruise at let's say 1500 RPM we overcompensate & the result is a fluctuation in overall engine speed 1250 to 1750 to 1400 to 1600, just trying to keep a steady 1500.
Dave |
If only K&N made fuel filters- think of the power and economy!!! :eek:
I thought the dirty air filter thing was from back when cars were carbureted. Doesn't a restriction in airflow act as a choke, making the engine run rich?
Frank Lee, what is your reasoning behind the K&N fuel filter. I run a K&N air for my truck, I noticed a difference right away. Is it an ultra low restriction gas filter?
Dave |
...if you use both a K&N air filter and a K&N gas filter, you'll save so much gasoline that it will backup and overflow the gas tank capacity, causing hydrocarbon air pollution and a fire danger (wink,wink)!!! |
Just think, you could stop in at gas stations...
to get paid for filling their tanks! :eek: |
I wonder how many will remember!..............
Oh The Pain.........Oh the pain!!!!!!!!! :D |
Quick, somebody slap a K&N sticker on a Fram fuel filter!
Better yet, I'm going to tell them that it doesn't need washed at all - you just remove, flip it over, and install it in the other direction... :rolleyes: |
(I actually have 30 micron fuel filters that you don't replace, you just wash them backwards and reinstall them. They're stainless mesh
Do you really? What vehicle or fuel, do you use them for? I don't know if I've ever seen a 1 micron SS mesh filter. I didn't know they made them that fine.:) Dave |
It's a stainless mesh inside a glass tube, when it gets crudded up, you take them apart and clean the mesh, then put it back together and you're good to go. They're inline type filters, like the WIX ones that you can buy from the parts store for $2, except mine are like $10. Refills for them can be gotten from Summit and even some L&G stores. |
Sorry I took it as 30 1 micron fuel filters, & not how you intended a 30 micron filter. That I have seen in SS mesh.
Thanks for the clarification, Dave |
Oh, noes! If I had access to 1 micron SS mesh, I'd be selling these things at a premium!
