Does a Kamback help on an insight?
I have enough election signs to do a Kamback for the insight, would it help or hurt mpg? I don't want to waste my time cutting/measuring/mounting for less than a 5% impact.
Balto, the lines on the Insight are pretty good as-is. I don't know how effective a Kammback would be.
Only a handful of production cars have ever had a drag coefficient lower than the Gen-1 Insight: 0.25 Honda Insight 1999-2006 0.2455 Tatra 77 1933 0.24 Mercedes-Benz S-Class 2014–Present 0.24 Mercedes-Benz C-Class 2014–Present 0.24 Tesla Model S 2012 0.22 Mercedes-Benz CLA Blue Efficiency Edition 2013-Present 0.212 Tatra T77A 1935 0.195 General Motors EV1 1996 0.189 Volkswagen XL1 2013 I might do a grill block and some under-body panels on Turtle, but mostly I'm trying to improve my driving techniques |
Extending the tail a bit would help. I suspect adding some sharp lines to the back to help with clean air separation might be worth something, which extending the tail would also do. My only concern would be visibility, which is already fairly poor in our car.
http://i.imgur.com/zB6TiHy.jpg http://i.imgur.com/QjAHRfJ.jpg |
1st-gen Insight
Your Insights roofline is right at the ragged edge of attachment
http://i1271.photobucket.com/albums/...titled-7-1.jpg Not as bad as the 1st-gen CRX,which I tried to correct http://i1271.photobucket.com/albums/...d2/Scan102.jpg http://i1271.photobucket.com/albums/...d2/Scan101.jpg http://i1271.photobucket.com/albums/...ntitled310.jpg You can see how Honda lofted the roofline of their 2nd-gen CRX,netting Cd 0.29. http://i1271.photobucket.com/albums/...ntitled9-1.jpg With the flow attached all the way to the rear,adding the elongation brings the wake area down and base pressure up for an overall drag reduction,as you see the the Mrecedes-Benz C-111 III http://i1271.photobucket.com/albums/...rawings1-1.jpg Theoretically,your drag potential would just be a function of the amount of elongation. An idealized aft-body would allow the bodies drag to approach the drag of half-bodies,and with wheels faired,perhaps Cd 0.12,maybe a tad lower http://i1271.photobucket.com/albums/...titled-8-1.jpg The drag trend would follow as in this table for a streamlined half-body with wheels in ground proximity http://i1271.photobucket.com/albums/...d2/8-3-133.jpg |
