Double Tank Mileage Contest
Hi,
Mileage rallies have all but disappeared so I decided to kickoff a world-wide, year long, double tank mileage contest. For this year, gas powered, Prius-only, as I know how to handicap the different models. If it works, next year we'll look at expanding it . . . assuming we can find sponsors for the awards. For now, the rules are posted at PriusChat only because I hang out there: Double Tank Mileage Contest | PriusChat The contest starts June 1, 2014 and goes through May 31, 2015. An experiment, we'll see how it goes. Feel free to share this with other forums. Bob Wilson |
I use to be into stuff like that, but then I learned to what extend people go to "cheat". Inflating tires to 120 psi, gutting the interior of the vehicle. Shorting the fluids a qt in the tranny, engine, radiator, draining the windshield washer fluid just to name a few.
When I did mpg runs I used the cruse control and filmed a segment with youtube to show the settings on the ac, heater, radio, etc. |
All I'm looking for is an ending photo like this: http://hiwaay.net/~bzwilson/prius/1000mi_721a.jpg
Seriously, if you see a problem with the rules, let me know. The contest does not start until June 1st and I'm OK with fixing problems before the start. Bob Wilson |
I want to compete against the Prius's , to put them in their place as the prince of mpg's not the king !
If anyone fails to meet the rules requirements, I'll reply they are disqualified and there will be no prize. Then I might send a note to the moderators about 'this troll' or just put them on my ignore list. Now if you would like to sponsor another make and model:
GOOD LUCK! Bob Wilson Huntsville, AL 35802 ps. As a practical point, TDI vehicles tend to have lower MPG at slower speeds. As they go slower, their fuel efficiency suffers. For example, the 2014 Jetta TDI is listed as 30 city and 42 highway and a range 493 miles, 14.5 gallons. To be competitive with the Prius that has auto-off built into the control laws, the TDI driver would have to stop and bump-start the engine for a whole tank, 986 miles. Now I'm OK with those who choose to drive their TDI by forcing the engine-off, coasting, and then bump-starting. But for 986 miles, twice the EPA range, it would be unpleasant. Perhaps if someone used a microcontroller to handle the auto-stop and restart during coasting (i.e., clutch-in, accelerator off,) it might work, but this is not a trivial technical problem. In contrast, the Prius has auto-stop built into its control laws at speeds under 42 mph and 46 mph for the more recent models. So as the Prius runs slower, lower drag energy losses, the Prius is able to exploit low-speed drag. For example, look at my average speed to achieve 1,000.8 miles: http://hiwaay.net/~bzwilson/prius/1000mi_721a.jpg I drove this distance using cruise control at 26-27 mph . . . for over 45 hours. This is a 'go slow' contest and just as boring which tends to be uninteresting to "Type A" personalities. |
I think that for all tanks that exceed double the range, the winners should be those with the highest average speed.
That makes the challenge more interesting and competitive. Doing it at the fastest (slow) possible speed is harder to do than achieving fractionally more mpg or range past a double tank. Driver technique and car preparation are tested far more trying to push the average speed. |
Bob Wilson |
Hi,
I've updated the rules to clarify:
