EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Doubts about MPGuino (https://ecomodder.com/forum/showthread.php/doubts-about-mpguino-26527.html)
josemapiro 07-30-2013 03:03 PM
MPGuino intend to apply to my Honda Civic, but I noticed that the image of the schema that is on the official website has a resistance ranging from 12V for LCD, different from that in the scheme of the Eagle, has a resistance of 450 Ohms and the other a resistance of 80 Ohms, which is correct.
Another doubt, the engine ECU has connections for each injector, as you can see in the link below, how can you be sure that reading only one injector is right since the other 3 injectors, may have different opening times.
It would not be possible to read the 4 injectors and add the 4 and then divide again by 4, so I think it would be more reliably reading.
img12.imageshack.us/img12/6027/6t4k.jpg
Sorry for my english
José Rodrigues
Occasionally6 08-01-2013 02:58 AM
Connecting to only one injector works because if the injectors do open individually there is not much difference between the opening times of that injector and the injectors that open immediately before and after it.
I don't know what your Civic does but in many older cars all the injectors open at the same time once per engine revolution anyway.
josemapiro 08-01-2013 06:05 AM
Thanks "Occasionally6"
I'll link to an injector, but I will try to understand the code and later talves will use the four, door is no problem because I use the Arduino Mega
Sorry for my Inglês.
Thanks again
José Rodrigues
