dragging dust
Noticed on my Kia Niro Suv a large amount of dust on my rear window after driving about 15 min on gravel road. What brought it to my attention was 2 other suvs a Rav4 and a Suzuki x7 which had little dust driving over the same road. So is my ecco niro having drag issues? Feel free to correct my grammar!
I'm thinking that accumulation is not by itself an indicator of bad aero other than where turbulence is being picked up into the wake from. The Rav4 has a higher drag coefficient of 0.31 to your 0.30 from what I found. Not sure on the Suzuki.
Perhaps you just drive faster? :D |
As Snax intimated, I wouldn't read anything into this.
My Insight gets virtually no dust on the hatch top window, which should have nearly laminar flow, but gets a lot of dirt on the vertical window at the back, where there is a lot of turbulence.
Some vehicles get less dirt on the back glass because they have a diffuser or slots through the rear roof spoiler to push clean air off the roof across the back window. My Forester had a plastic diffuser and my Minivan has a slot in the spoiler.
since it is a MK6 Golf pet peeve, does those rice racer vortex generators do anything for the vortex calming?
*Flow characteristics are related to the Reynolds number, which is the ratio of the inertial forces acting on the fluid particles to the viscous forces. When the inertial forces outweigh the viscous forces, i.e. Reynolds number is large, the flow will be turbulent. And since the inertial forces are the product of fluid velocity and test length, as speed increases or the point of investigation moves further along the body, Reynolds number increases. Since the kinematic viscosity of air is very small, 1.46x10^-5 m^2/s, it doesn't take much speed or much length for the flow over a car to transition from laminar to turbulent. |
Regardless it's pretty cool to be able to drive through a rainstorm and have a nearly horizontal window at the back of the car remain completely dry. |
Tires, engine fan, underbody.
transition length
