EcoModder.com
-   -   draining refrigerant HELP (https://ecomodder.com/forum/showthread.php/draining-refrigerant-help-20653.html)
IsaacCarlson 02-22-2012 07:30 PM
I have the sunfire in the shed and am getting ready to pull the motor. I need to remove the A/C system and can't get the car to a shop. I don't want to vent it and have placed a free add on craigslist for anyone who has the equipment to evacuate the system. I am not sure if there is even anything in it. My brother and I carried the car in the shed and around a corner. There is no way it is coming out right now. Any suggestions?:confused:
roosterk0031 02-22-2012 08:35 PM
Do they ever try to recover 134a? I wouldn't give it a second thought let it go.
TheEnemy 02-22-2012 08:45 PM
See if you local Autozone or other parts store might be able to lend/rent the equipment to you.
Rooster: Bad boy.:eek:
Sularus 02-22-2012 08:49 PM
R134 isn't bad. I have just let it go on several times while working on cars. I only do it with R134. If I run into the older stuff I will have it evacuated, but I don't see the need to with R134.
IsaacCarlson 02-22-2012 09:09 PM
is it dangerous to me?
will there be any residue to make things yucky and make the shed a mess?
roosterk0031 02-22-2012 09:25 PM
If you use your finger to push the pin to let it out it will get cold and possibly frost bit. Poke it with a screw driver and see if anything leaks out. Or just take a joint apart and watch for refrigerant leaking, it's just a gas with tiny bit of oil you probably won't see.
They sale the stuff at walmart so it can't be that dangerous or enviormentally unfriendly.
user removed 02-22-2012 09:26 PM
Can you remove the ac compressor and leave the lines connected? Or are you eliminating the AC system?
regards
Mech
TheEnemy 02-22-2012 09:42 PM
R134 isn't as bad for the environment as the old stuff, but its still not good for it.
If you can have it handled properly.
IsaacCarlson 02-23-2012 12:07 AM
the system is getting removed. I have a bypass pulley on the 3800 and like how the numbers feel on my butt o meter without it.
IsaacCarlson 02-23-2012 06:21 PM
HAHA...the joke is on me. The system was already empty! Good thing I tested first before trying to load it on the flatbed and take it into town. There was a small hissy puff and that was it. Saved me at least a day and a half.
I have pulled the right axle shaft out and have stripped the motor. Tomorrow I will get the left shaft out and then it will get pulled as soon as I find a way to lift it.:thumbup:
I don't have the cash for a hoist, so it will probably have to be lifted by hand.
I will keep you posted.
roosterk0031 02-23-2012 08:16 PM
I'm not surpised, even if you would have left everything sealed, eventually it would have been vented. Do it now or let it vent itself over next 4 years same result.
Keep us posted on the project, should be a fun ride. 3.8 in sunbird right using the sunbird auto tranny. Those 3.8's were a good long life, decent FE engine.
IsaacCarlson 02-23-2012 10:42 PM
It is a sunfire, but yeah, pretty much the same thing. It has a 4t40E tranny in it. The 2.2 will get pulled and the 3.8 will get bolted in. I got both struts off, as well as the control arms and axle shafts. The control arms need new bushings and I might need new struts. I removed the A/C today and removed most of the stuff under the hood. I could pull the motor tomorrow if I had a hoist.:(
Tomorrow I will be taking the master cylinder out, loosening the motor mounts, and removing the exhaust. I will also be pulling the gas tank to inspect the pump. The dash and seats have to come out so I have easy access to everything.
The tranny will be getting a new filter, gaskets, and seals. Of course this means new oil, which will be synthetic. The oil looked good when I pulled the right shaft, so I don't think there is anything to worry about inside the case.
As far as I know, the torque converters are interchangeable. I have not heard anything to the contrary. If this is the case, I will be using the one with the lowest stall speed, if one is lower.
So far so good.:thumbup:
roosterk0031 02-23-2012 10:56 PM
Sound's like a way more intinsive swap than when I put a 350 in a 4x4 s10. I lots a couple mpg, but no more downshifting every time the wind shifted or hit a 1/2 percent incline, and no more vacuum drop when getting into it when in 4x4 and the front diff unlocking.
IsaacCarlson 02-23-2012 11:10 PM
It doesn't seem very intensive, but I have been gathering info on and off for a few years and full time for over two months. I will likely have to fabricate a few parts, but it is nothing major. I will be adding a strut bar and front dogbones to keep the motor from tearing up the mounts or crashing into the firewall or radiator.
There is a lot of torque there and it needs to be tamed. There is no cradle under the motor/tranny. The only mounts are on either side and a small dogbone on the lower right. I will be adding some extra support to remedy the issue.
roosterk0031 02-23-2012 11:14 PM
Yeah way more that dropping in a v8 in a framed truck. I loved how everytime the 700r4 hit second and would squak the rears though. 16 mpg wasn't that bad.
I'm a rookie with FWD stuff, RWD, engine right 4wd I'll tear into, just haven't tore into FWD yet.
IsaacCarlson 02-24-2012 09:05 AM
Wow. Things are moving right along. I found a 2 ton motor hoist for $100 and am going to pick it up today. I have always wanted one of those.:rolleyes:
The cool thing is I can hang deer on it.:thumbup: I might have this project done sooner than I thought.
IsaacCarlson 02-24-2012 02:16 PM
starting update thread....see that one.:thumbup:
