Old 02-03-2010, 11:52 AM   #1 (permalink)
piers.singer's Avatar
Upgrading from lurker to newbie!
Good tidings y'all!
I'm Piers and I'm from England. I have been lurking on the site for the past few days now and I'm very impressed by some of the amazing FE figures being produced!
As for my own vehicles, I ride a 1994-ish Honda CB "Two-Fifty" (called Nighthawk in the US, I believe) and I get around 90mpg(Imp) out of it. Now considering that that is 72mpg(US) and some of you are getting that out of your Metros, I believe I have some work to do!
Spoken like a champion. Oh no, disaster!
Old 02-03-2010, 11:55 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yes, sir, and you've come to the correct place to do that work!
Welcome to EM. Is your name pronounced similar to "pierce"?
Your Honda CB250 is definitely a good jumping off point for working on good mileage, but as with most bikes, you're going to need to work out some aerodynamics enhancements to really get good numbers. Gearing could be a starting point for you, though.
Old 02-03-2010, 12:04 PM   #3 (permalink)
Thanks for the welcome! Yes, it is a bit. More of a "zzzz" on the end than a "suh" Or you can say it like "Pee-yurs". Up to you :P
All I've done aerodynamically so far is add a windscreen. Not much but added 5mph onto my comfortable cruising speed, possibly a few mpgs and helped ease my back pain haha. I'd really love to build a streamliner, but seeing as I've no money or expertise and the bike is my only form of transport, I'm a little apprehensive about taking it too bits right now!
Old 02-03-2010, 12:12 PM   #4 (permalink)
I suggest that you work on tuning first, really. See if you can lean it out a bit, if you have a proper way to monitor your engine. Driving technique is usually the kicker. Get 'er into high gear as soon as you can, and if you have to accelerate, don't downshift. Load the engine up as much as you can without it stuttering.
Swap your oil for something thinner, if you're comfortable with it. Of course, driving slower will also up the mileage for you. Remember that any time you're sitting still, or the clutch is disengaged, your engine is burning your money and doing nothing in return. Turn it off if it's not driving the bike. Idling is bad for air-cooled engines anyway, in most cases.
If you're really interested in doing aerodynamics work, you can start by adding functionality to the bike. If you never put anyone on the back of it, you can trim down the seat, add a trunk (make it yourself, if you can) and taper the shape back so it forms a cowl/backrest that slopes into a sort of fish tail. You can add side bags, tank bags, etc. so that you can carry stuff in the space that an aerodynamic shape will occupy, and those things, if smoothed and tapered properly, will help the flow of your bike as well.
Beyond that, you can begin adding a framework for some body panels just by bending up old wire coat hangers into a frame, then stretching some window screen over them. It'll look like hell, but it'll get the job done. At high speed, air passes over a tight screen, rather than through it. Leave a cooling area for your engine, and don't cover up the exhaust too much - gets hot around there.
I suggest you check out Craig Vetter's site for more ideas and inspiration about aerodynamic forms and motorcycles.
Craig Vetter Fuel Economy better mileage
Old 02-03-2010, 12:49 PM   #5 (permalink)
Thanks for the ideas, Christ. Reading Vetter's page makes me wanna do something wacky, so who knows what I'll do? Stay tuned
Newbie Question about Garage ratherbehiking Introductions 1 05-08-2009 11:38 PM
EcoMod Lurker needing help with wrecked Civic HX HDCaptain Introductions 7 12-08-2008 07:55 AM
Hello - longtime lurker AppleMac*Fit Introductions 2 11-12-2008 11:11 PM
Newbie from the Philippines gasti_ako Introductions 5 09-08-2008 01:36 AM
