Old 11-08-2020, 10:05 AM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Need advice on GoPro / GoPro alternative and suction cup mount for tuft testing
I am seeing some cheap GoPro cameras on Ebay.
I plan to do tuft testing with them.
My main question would be about the suction cup mount.
I have seen videos of these things mounted to almost everything from submarines, to rockets.
How do they work ?
Do you need a slick surface for it to get suction ?
I would be a bit nervous about the thing falling off the car .
Would they stick to Coroplast ?
Please post your experience with them.
Are there certain models I should avoid ?
I notice some have WiFi - what is that all abour ?
I just need the cheapest, basic setup that will show what the tufts are doing without falling off the car.
Anyone here have a GoPro alternative that you would recommend ?
Thanks !
Old 11-08-2020, 11:38 PM   #2 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
The suction cup works best if you clean the surface, then apply the suction cup. If the surface is damp I think it has the potential to work a little better, but not sure on that one.
You can always add a tether to a mirror housing or strong magnet placed nearby.
I don't think it would stick to coroplast very well. Too much flex. I've never tried though.
I think the wifi has 2 purposes. So you can remotely see if you are in frame and I think you can save the video to the connecting device.
I have a SJ4000, the original knock off gopro. It works good enough. I paid like $50 for it used with some basic accessories. It accepts all gopro mounts.
The last time I used it was when I was assembling a harbor freight trailer. The file is saved on my laptop though and I can't find the charger. Otherwise I'd share it. It works pretty good for the price. I did buy a knockoff gopro before I bought the SJ and it wasn't that great.
Edit:
I'm 90% sure this was recorded with the SJ.
I am going to try this for a mount. I already bought the suction cup. It is works really well, but it has to be smooth, flat surface. For example, my fridge door has little dots/shapes and it wouldn't stick. The side of the fridge is completely smooth and my 65 lb dog couldn't pull it off.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
Cd (11-13-2020)
Old 11-10-2020, 04:47 PM   #3 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Go with a camera that has a built-in display as it will allow you to instantly confirm that your camera shot framing is optimal for the desired task.
My current setup (1st gen. GoPro) involves recording-removing SD card-validate framing in laptop-adjust framing if needed - THEN I can proceed with recording the actual video. Very time-consuming.
I believe newer generation cameras can broadcast the video feed to your smartphone via WIFI; could be handy if you want a "live" feed.
The Following User Says Thank You to CigaR007 For This Useful Post:
Cd (11-13-2020)
Old 11-11-2020, 12:23 AM   #4 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I am not sure if you are referring to my suggestion or just in general, but the SJ4000 does have a screen on the back side of it.
1995 Mercury Tracer
