Old 09-15-2008, 04:06 PM   #1 (permalink)
Neon1 - '97 Plymouth Neon highline
90 day: 27.26 mpg (US)
Best around town mileage to date
I finally cleared the 30mpg range around town with the auto. The only real changes have been shifting to neutral at stoplights, not running AC (it cooled off enough to not need it) and working more on keeping the Neon below 2500rpm on accel.
Most of the other mods I have done have been aero, and around town it just does not help that much....
So off for the next quest....31MPG
always in small steps....
Jim
Old 09-15-2008, 04:10 PM   #2 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Did you try turning your vehicle off if you are the first to the red light? You just have to look around for when the other direction's light turns yellow as an indicator to when you turn your car on. I think you should be able to surpass the 31 mark with that change.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 09-16-2008, 10:29 AM   #3 (permalink)
Nope, as I have said before...I am more into making the vehicle efficient than the whole hypermiling thing. I am still unconvinced about turning off a hot car (water pump stops as well, temp goes up) especially on a car known for head gasket issues. Additionally there is the wear an tear on the starter, flywheel, keyswitch etc. The ability to shift it into drive and move quickly if needed....which I have had to do in the past...is not really different than having to shift a manual and let off the clutch...so I am comfortable with that. Additionally, my Dodge truck manual actually suggests putting the auto trans in neutral at stoplights (for cooling when towing) so I can see that what I am doing is withing the design parameters of these vehicles.
25mpg is what fueleconomy.gov lists as the combined mpg for this vehicle. If I am getting 5mpg better just around town...I am happy with that.
Over the winter, I'll likely be switching the trans to a manual (already have a donor car) and driving the cherokee in the snow...so next spring the mileage will be better still....
Jim
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
Winters coming! how do I keep my mileage up? Mr_C EcoModding Central 45 09-11-2008 04:56 PM
