Dual OEM AC EV motors, one drive?
Hello all,
Been keeping up with the development of MPaulHolmes' "Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control" and the gears are spinning merrily in my head. I'm still a ways off from being able to afford a conversion, but using 1 or more Nissan Leaf motors with this 200kW capable controller looks like a winner from a bang for the buck perspective. I have what may be a motor or controller theory question, and please keep in mind that I'm a Mechanical Engineer, not an EE. I would like to run two Leaf motors off one controller, based on my assumption that it doesn't seem likely that the Leaf motor is overbuilt enough to put out much more than 100kW without increasing the voltage above a stock Leaf battery pack level, due to hitting the current saturation limit (or something). A single motor is "enough" (80kW constant rating at 7000RPM will theoretically push my theoretical EV up a 6% grade at 60-70mph), but I want more, of course. If a single leaf motor can handle 200kw short term (or longer with additional cooling), then no need to pair up. Theoretically, this can be done - at least, it is common in industry to run multiple AC motors off a single VFD. However, the Leaf is an Interior Permanent Magnet type AC motor, thus if I understand correctly it is a synchronous type and operates without "slip", and this complicates the process of trying to parallel two motors. I have an idea of what I would need to do to make two IPM motors work on one drive, so please follow along and let me know where I made my mistakes, and correct them if possible. Poking around on the web I found some quite good cutaway views of the Leaf driveline, one included a teardown of the motor itself, showing that the rotor lamination stack is keyed to the main shaft (more like two very long slots on the shaft, 180 degrees apart, and the laminations have an integral pair of tabs that fit into said slots). Thus one could "easily" make a longer shaft and press two rotor lamination stacks onto it, and expect them to be very well aligned. The stator windings/lamination stack is press-fit into the cooling-channel equipped main motor housing - it is unclear whether there is any keying there. The "simplest" way to pair them up would be to machine an adapter that would connect the "front" of one stator housing to the "back" of the next housing, with the stator slots aligned. Obviously the stator spacing would need to match the spacing of the rotors on the new common shaft. Re-assemble, and you have a double-length motor with two rotors on one shaft, two stators in paired housings, each with their own cooling jacket and stator wiring connections, and one can use a factory front and rear housing end-plate and bearing setup on the ends. Custom work can be done to add additional cooling to the end-turns if desired. Is this sufficient to align the two motors well enough to achieve proper operation when the stators are connected in parallel to the controller, or do I need to set up my "stator housing coupler" to be adjustable and play with the alignment until I get some measurable electrical output from the two stator windings to match? If I need to play with it, what sort of electrical output do I look for? I thought I could set it up and spin the rotor and watch the AC waveforms from the two stators on a scope and adjust the two housings relative to each other until they match as closely as possible. Or, I could run the paired motors off the controller at a low current and adjust the relative position of the stators until max torque is reached - but this is a much harder setup. On the electrical side of things, once the two motors are aligned, do I just hook up the two stators in parallel - making sure the correct phases are connected so the unit doesn't fight itself? Do I need to carefully adjust the wiring resistance so they are equal, or is inductance more important, or both? How critical is this adjustment? I would then use only one encoder/resolver for the paired motor. Thoughts? This seemed more straightforward than a custom gearbox to accept two Leaf motors and combine the output into a single output shaft - trying to align the two rotors through the gears adds the problem of slop and having to re-do it every time you pull a motor or strip a gear. Alternately, if the two motors cannot be paralleled on the same drive for electrical reasons, can the twinned motors be run from a pair of inverters in master-slave mode, assuming the motors are aligned well enough that the single resolver is accurate enough to provide rotor position information for both motors? How about if two standalone motor/encoder/inverter sets are mechanically connected? What would be awesome is a way to run two stock Leaf inverters this way... Note that both ideas can be extended to pair up two or more of virtually any available wrecked OEM EV motors and possibly their inverters, depending on motor mechanical setup and inverter electronics/control scheme. Thanks! |
http://techon.nikkeibp.co.jp/english...4/193591/2.JPG
http://techon.nikkeibp.co.jp/english/NEWS_EN/20110724/193591/?SS=imgview_e&FD=47620101 The other thread you might look at is Hot-rodding the Toyota MGR. The OP, e*clipse, is working on combining two of the MGR in a custom case. It's rotor splines onto the shaft. He might be interested in or have answers to your questions. Arcimoto use two electric motors in front-wheel drive. It's not clear to me if there is a differential or the controller[s] provide the differential action, driving each wheel separately. To what will you custom shaft connect. IOW base vehicle, front or rear drive, lateral or longitudinal, etc. Have you considered putting one MGR on each end of the car for 4WD? |
Hello freebeard,
I've been keeping up with that thread as well. Intended application is an old 4x4 FJ-40 Toyota Land Cruiser. If axle-mounted motors get a sufficient torque/speed spread without having to change gears by the time my budget is available, I could go 1 motor per end or per wheel, but at this time it is far simpler to run everything through the transfercase and driveshafts to the existing front/rear live axle setup. For off-road application, the setup to meet or exceed is ~6500 ft-lbs at the axle (with locking diffs, that can be all at one wheel, or divided amongst all 4, depending on how many are in the air/on a slippery surface) in low range. (250 ft-lb gas engine, 3.555:1 first gear, 1.96:1 low range, 3.73:1 axle gearing - total of ~26:1 gearing). Gearing lower (which is cheap down to about 66.5:1) becomes less important so long as sufficient torque is available. Gas engines need gearing to keep enough torque available at slow speeds without stalling the engine or burning up the clutch or torque converter. With insufficient gearing, you end up going too fast sometimes, which means more things busted/broken/bent. With an electric motor being a "constant torque" source below a certain RPM, stalling isn't an issue. For on-road application, acceleration "feel" must meet or exceed the stock 125hp/250 ft-lb gas engine with 4-speed truck-type manual trans and average-ability driver. Pretty low bar to clear. If it isn't fun, it isn't worth it. Self-contained range requirements are low - a stock used (cold-climate, so 9-10 bars showing on the battery still) 2011 Leaf exceeds my needs at present, even in winter. I'll figure out how to get it to remote off-road locations and how to recharge it there later. It'll be a fun commuter first. |
Congrats on having an FJ-40. I have some friends that keep saying they're finally going to sell the family Scout II.
You may be able to extrapolate from putting an AC motor on a VW transaxle. First gear is useless. Second is a good low end, for pickup. You can drive in 3rd all day if you don't mind oozing away from stop signs. 4th is like an overdrive, but the motor hits the knee in the torque curve and chokes. I'm no help at all when it comes to machining shafts and adapter plates. |
To my knowledge (please - I`d love to be wrong on this one!) no one does sensored or sensorless vector control, Field Oriented Control, etc with more than one motor per controller. Quote:
So making both motors put out full torque with the same signal when they are coupled is quite a challenge. I won`t say impossible .. but I will say much more math to prove one way or the other than I`m up for! Quote:
Hello again freebeard and thingstodo,
freebeard, I currently don't have an FJ40 - haven't for over a decade. See, I had one as my first and second vehicles (rolled the first one, put over 100K miles on the second) and then mostly parked it after graduating from University and needing to work. Eventually I moved, and took it with me, and by then it needed more than just some repair. So I took it apart to "restore" it but had no money, so it got piled up in the back yard and sat for ~7 years, and then I sold it and started a family and all that. I want back in, but I DO NOT WANT the ~12mpg mine had or the ~20mpg a diesel would get. A diesel conversion done right would likely be close to the cost of an AC EV conversion, if I can use junkyard OEM EV parts. Plus I want to be different. :-) Scouts are cool, too, but also suffer from Demon Rust - and I imprinted on FJ-40's, so they're not really what I want. if one has the cash, fiberglass body parts are available for both, and Aluminum for the 'Cruiser. As for how the AC motor feels through a transaxle, that is good to know. Do you have an HPEV's AC setup? When you mention the torque hitting the knee and the motor choking, I recall from the peak power graphs for their motors that HP does actually peak on those, with the downslope almost as steep as the upslope, whereas on the OEM EV motors I'm thinking of (Leaf, Volt, etc.) they do a flat constant power region after the flat constant torque region. Should help some. There'll be a point at which it makes sense to shift up after the torque falls off too much, but it'll be a wider spread. I want liquid-cooled AC so I can sit there "stalled" on a rock without burning it up, and if it can keep liquid in I can seal it well enough for a dunking. Air-cooled brushed DC would be relatively easy/cheap, but keeping water out is much more of a challenge. thingstodo, thanks for the insights! For aligning the two motors, I considered the rotors aligned by way of their built-in keys good enough, with the rest of the work being in aligning the two stators. As for possibility, AMR appears to sell "dual core" motors with single inverters, and IIRC those are IPM type REMY motor cores. No idea of the math needed, though! Sounds like trying to run two IPM or SPM or similar motors off the same drive may not be worth the hassle. How much less critical is it to get two stator windings for induction machines equal in terms of resistance/inductance when running them in parallel off the same drive? You said it is possible to run two OEM AC motor/drive combos in master/slave mode on a common (or geared/belted together) shaft. Any ideas as to how to control those drives? Mostly thinking OEM EV drives here - for common junkyard availability. For the aftermarket Curtis controllers, and many common industrial VFD's, they have that feature built in - just connect them up and put in the right settings. Not sure that is the case for OEM EV drives - and it seems like it would be an extra-cost thing that wouldn't be worth it to the OEMs to implement. Hmm. I guess I could send the throttle signal to a separate "controller controller" and have it divvy up the torque demand to the two OEM drives, possibly with a current sensor on a phase of each motor to have a feedback for how well balanced the setup is running, if needed. Or just twin the throttle output and send it to both controllers at the same time, maybe monitor the current on/temperature of each motor for a while in early days to check the balance and see if it needs adjusting. I've got lots of time to plan this out as the budget builds all too slowly. I'll probably end up buying a used Leaf to replace my currently dissolving ICE car as a commuter (different budget - I need to commute, after all!) for my first EV, as my toy budget may get big enough to buy a running/driving FJ-40 before it gets big enough to buy enough good parts to build one plus the EV bits. Thanks! |
*WARNING * another long-winded post!
I don`t know of any research on-going at the moment to drive multiple motors of any type in Field Oriented Control or sensorless vector. If the nerds are not arguing about it - there must be an obvious problem or two. Quote:
With a modern dual-signal hall effect sensor, you could .. in theory .. send the same throttle signal to each controller. The controllers *COULD* fight if one of them saw the signal as slight regenerative braking while the other saw the signal as slight acceleration .. but the calibration curves for the throttle should take care of that. There`s always a bit of deadband around `coast`. That should take care of it. Quote:
Going back to a Jack Rickard (EVTV) video - you would need some sort of limited slip arbitration, or ABS maybe, so that you do not break loose one rear tire while accelerating through a turn. Quote:
Making things work with OEM parts has some advantages: - if you sell it eventually, the new owner can find parts and has confidence that he can - you can go and buy a part off the shelf to get back running ... if you need to .. or you can get another wreck or buy something from a wrecker - Comparatively little issues with `that company is out of business, or the part is obsolete so you can`t fix it`. The alternative, for me, is Open Source. I`m not dedicated to building the boards, or soldering, or writing the program myself. But if you have the schematics you can troubleshoot it yourself. If you locate something that died - like an IGBT - you can buy a replacement and put it in, or get someone at a maker space to put it in. You have the power! The software may not be as bullet-proof as an off-the-shelf product .. but it may be better .. depending on the guys doing the open source. If you see some new feature in a car in 2 years .. and you want it badly enough .. you can add it! Boy - I do rant on, don`t I? I will follow your build with interest! |
Hello again thingstodo,
I've seen a few papers out on the 'net, but without the EE background I can't tell what's BS and what's not. Quote:
I'll likely keep asking questions here and there on this forum as I get ideas I want to check. Thanks! |
To get full torque on a 3 phase motor rotor inductance and reactance have to be equal, this usually happens at 20% to 30% rotor to stator magnetic slip speed.
Somewhere around to top of the curve where the motor runs out of torque and stalls... somewhere 2X - 4X rated torque, way over rated slip, way over rated current ... stuff that you do for short periods of time ;) |
My statement covers both.
If the motor is operating below 70% slip it is not developing full torque. When the motor slips too much the internal cross bars in the rotor start to operate on higher and higher inducted frequency. The problem is the stator is almost always designed to run at peak efficiency well under 10Hz. Increased slip just creates more heat, not more torque. |
freebeard:
HTML Code:
http://www.diyelectriccar.com/forums/showthread.php?t=151458 Quote:
thingstodo: I like the "sanity check" feature of the two different voltage ranges on the throttle. If I am "twinning" the throttle output to two separate drives, so long as both drives can handle those two voltage ranges, then there should be no issue. IE, use the throttle assembly that goes with the donor drive(s). If using a non-OEM drive, I've got to figure out whether I want to put in that sort of fail-safe, and how to handle it. Possibly with the GEVCU? Haven't read up on it at all yet. Hmm. I wonder whether eldis' UMC drive HTML Code:
http://www.diyelectriccar.com/forums/showthread.php/any-ac-motor-any-inverter-umc-152234.html Thanks, all! EDIT: links are not links yet, guess I have too low a post count, or didit worng. Seems legible, at least. |
I plan to do a similar thing with Paul Holmes' AC controller board. I have *SEVERAL* old industrial Variable Frequency Drives (AC in, variable speed or variable torque AC out) - Allen-Bradley, Siemens, Mitsubishi, Toshiba ... all air-cooled so they are heavy .. and with one thing or another not working. I would like to do a brain transplant on them and use them (since they are designed with 600VAC parts and tolerances, touch-safe enclosures) for battery chargers, DC/DC converters, and perhaps even single-phase 120/240V to power my shed. None of them are suitable for a car - the heat sink being double the weight of everything else in the drives, huge inductors .. etc. But I might be able to help Paul make his control board easier to use when driving 'foreign' controller structures. We have discussed that it would be nice to add another CPU, on a different board, to Paul's AC controller (and come to think of it, his DC controller as well) to do the CANbus interface, making the data pretty for a bluetooth link to android .. and a host of other things that the Motor Controller *DOES NOT* need to spend time on. IMHO reliably controlling motors is enough of a task! |
EVTV Motor Verks Store: They have the GEVCU, SavvyCAN that can read and inject CAN messages at high speed, the older CAN KIT with Arduino Due, the 1000 or 300 Amp shunts that are on the CAN bus; even (I see) a CAN-GPS that put geo-location on the CAN bus. |
The motors will be set up from the factory.
I just figured you would run 2 of the same motors. The resistance of the windings is fixed, the reactance is varied by the current in the rotor and stator. Varying the voltage and frequency to the motors will be your torque regulation. There are other tricks to get higher torque such as putting series winding in parallel for starting. But this is a special class of industrial motors, I don't think traction motors use it. |
thingstodo:
Sounds like a great idea to have a "universal brain" one could plug in like that, for all the reasons you list. I like the idea of re-using already "safety rated" enclosures! Quote:
Well, yes, 2 of the same motor. I was wondering how similar they had to be, or whether "factory tolerances" are good enough as-is. Sounds like I should reasonably carefully set up the main cables running to each motor so the per-motor phase resistances are basically equal. Quote:
True, but my target application (dreamland, I know, lots of built in assumptions in terms of arranging recharging, etc.) is off-road. Getting sufficient torque to the one wheel that has decent traction to get over that rock while still retaining a sufficient speed spread in the same motor seems quite a tall order. Linking two motors across one axle with a "locker" of some kind (basically a normally open clutch between the two) halves the per-motor torque requirement, but it's still pretty difficult to get it. Were I building a vehicle that would never go off-road, 1 Leaf setup per end or 4 geared motors, 1 per corner would work fine. If I build what I want - an FJ-40 - it must retain at a minimum the off-road ability of a stock driveline, so 6500 ft-lbs at the axle in low-range-first-gear. That got me pretty much everywhere I wanted to go off-road before, the limit was traction and ground clearance (no lockers at the time, and no lift). Freeway specs are modest, so not difficult to achieve. Quote:
Yes, it looks like EVTV has a lot of the bits I'd need to splice some OEM goodies together. One of these days I'll have to watch some of the videos there, too. General question to all, sort of off my original topic: What are the safety implications of using two complete Leaf battery packs, connected in series, to give ~800V to MPaulHolmes' 200kw inverter? If the + and - from each pack is fed directly to the box the inverter lives in, then aside from touching the wrong two battery posts, or chafing through both the + on one pack feed wire and - on the other there should be no voltages exposed that are higher than a stock Leaf. There'd be contactors within the inverter box to split/combine the packs based on whether the car is in "charge" or "drive" modes, and the packs would likely be charged "in parallel" (either two packs and two chargers run separately, or two packs paralleled on one charger). I'm basing that query on the idea that doubling the voltage *roughly* doubles the RPM at which peak torque can be maintained from a given motor. Other than the additional losses from running the motor outside its' design envelope, that should give roughly double the power at stock current levels. Extrapolating from the existing ratings, and using stock current levels, that's still ~207 ft-lbs 0-2200RPM, ~192 ft-lbs 2200-6000 rpm, ~215hp 6,000rpm to 10,300rpm (keeping stock redline). If we take 200kW input to the drive, and take a 90% drive/motor efficiency, we can get ~241hp at 6000rpm on up, so ~211 ft-lbs 0-6000rpm calculating backwards. The motor would still happily run at 107hp/7,000rpm constant rating, which is "enough" for long-haul and hill-climb needs. (battery capacity limited unless fancy range extensions are figured out. Probably a pickup truck and a trailer...) Higher if cooling can be improved - and one motor is easier to cool than 2. Thoughts? |
Hah! I've seen something similar on Craigslist, though no hardtop and stretched on a 2WD S10 chassis. Okay, lessee, going by what I know of US trucks, that's at least a RHD windshield of '76 or newer, '76 or newer doors/top sides, pre-'79 rear upper hatch (but newer than sometime in the mid-late 60's), pre-'79 front bib. '76-'78 gas door. Hmm. No way to tell if 4x4 or 2x4 - can't see the front leaf spring shackles, might be hidden by the non-stock bumper. Area under the right front fender is too dark to make out any suspension details. Very likely a non-US truck. Rust looks about the usual, though the area below the right front door is surprisingly nice compared to the rest. Might be patched, though. That might be a power steering box sticking out of the bib over the framerail opposite the two guys standing by it. That would confirm RHD. Not a typical Saginaw conversion fitup, so might be on a donor frame, or some non-US swap. Front frame horns appear too short, and the usual crossmember under the front bib appears to be missing, which points even more to a frame swap of some sort. I'd have gone the rest of the way and chopped the top, too, if I were doing such a beast. Looks like a "what can we make from what's lying around in the field behind the shop?" special. Not my cup of tea to take something that was factory 4x4 (with no 2wd option that era outside of possible specialty applications) and remove that capability, but a rusty FJ body isn't worth much. The other 'way round, though, that I can see. VW Transporter on a Steyr-Puch Pinzgauer chassis, for example. Sort of a DIY Syncro. Would need a custom center chassis section with some sort of lockable viscous coupling between the front and rear axles, and a custom gearbox with the low-range box inline to allow hanging the engine off the back end. Might need to swap the ring gears side to side to correct rotation, too, depending on how it turns out. Yes, I seem to gravitate towards complicated... |
You found a lot in that one picture. :thumbup:
http://ecomodder.com/forum/member-fr...1396746884.jpg Something like this, you could drop the FJ40 (43? 45?) onto a Subaru 6-cylinder 4WD chassis. The 6-8" lift area becomes storage lockers. |
Some might say the same thing about the whitewalls. :)
As per my knowledge multiple induction motors on one controller are done in Volts per Hertz mode.
Every output voltage has a corresponding frequency output. It gives you more than one motor`s output in vector mode, but less than a controller per motor. |
