Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 02-26-2008, 12:45 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
5 DIY Truing Stands
This is a pretty neat blog post tht came up recently discussing five methods of making your own truing stands...no need to shell out the big bucks, eh?
http://bikehacks.com/5-diy-truing-stands/
Old 02-26-2008, 04:11 PM   #2 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
I was going to say...can't you just flip the bike upside down and do the same thing that they said in the first option with the forks in the vice...
Great article though, if I ever have a need to true my wheels more then once or less per year then I will remember to look at the article again for tips on making a stand. However, I don't really abuse my commuter or race bike so they stay pretty true with normal use anyway.
Old 02-26-2008, 04:30 PM   #3 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
My truing stand is an old bike flipped upside down.
That is the way I've always done it as well.
If I ever get a spare fork, then I'll definitely do it that way.
Old 02-26-2008, 04:32 PM   #4 (permalink)
Send a message via AIM to Gone4
I've never actually trued my own wheel.. is it a long process?
Old 02-26-2008, 04:38 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
I only did a minor truing after replacing a broken spoke on my race bike and it didn't take much time at all.
Old 02-26-2008, 04:58 PM   #6 (permalink)
Bicycle Junky
NoCO2's Avatar
the idea is just making it not wobble and for most applications a rough truing is all it takes, the only exception being race bikes going 40+mph. But for most people the zip tie around the fork of a bike flipped upside down works just fine.
::EDIT::
O, I also meant to ask. Is there a good way of truing a wheel that has side to side wobble as well as the unbalanced wheel type wobble?
Old 02-26-2008, 05:04 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Do you meant to say the rim is bent?
Old 02-26-2008, 05:07 PM   #8 (permalink)
Bicycle Junky
NoCO2's Avatar
yea I think that's the problem. I'm not sure though as it's my roommates bike so I'm not sure what happened to it. It does appear that it's bent. Is there a way to fix it or is it just recommended to get a new wheel in this situation? I've actually never done this so I've never had to fix anything like it before. He is on a tight budget to get his bike fixed so I was just wondering if there was a way to avoid buying a new wheel assembly.
Old 02-26-2008, 05:12 PM   #9 (permalink)
Dartmouth 2010
SVOboy's Avatar
If the rim is indeed bent I would advise on a new one, but I don't really know what you're describing so it could just be that the wheel is really out of true.
Old 02-26-2008, 05:17 PM   #10 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I have a cheap $35 trueing stand, it works well, other then the fork has no adjustment, insted it's slightly springy you need to use the skewer or axle nuts to hold the wheel in place otherwise it slowly wiggles out, but it's light and compact folding almost flat so I have it mounted on a small piece of plywood and hang it on the wall, if I didn't have it then I would either get one of the dial indicator holders that clamps on to a standard fork, or do what I did befor and head down to the bike shop and use their stand, doing it that way is cheap and leaves my shop less cluttered.
I've personaly built 4 wheels, and re-spoked a few as well, my last one was a 700c rim on a 3 speed hub and bolt that on to a racing frame, but mostly I use it for when I get a bike from the dump that has a broken spoke I can replace the spoke and true the wheel, once you get the hang of it it's pretty easy, taking 15 minutes or so, building a whole wheel can take a few hours, it's pretty easy as long as you have a decent attention span for repitition.
DIY - Water Injection Stormin' Norman DIY / How-to 46 12-28-2012 12:48 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
DIY - Black Trim Painting SVOboy DIY / How-to 14 12-15-2008 10:46 PM
DIY - Ambient Air Fridge NoCO2 Saving@Home 13 05-10-2008 09:18 AM
DIY Needed - adjusting parking brake pull Yaristock DIY / How-to 22 04-17-2008 09:51 AM
