EcoModder.com
-   -   E15 vs E10 (https://ecomodder.com/forum/showthread.php/e15-vs-e10-34208.html)
roosterk0031 08-18-2016 05:17 PM
E15 vs E10
1
MPGeo 08-18-2016 06:50 PM
In 2-3 occasions I have used E15 to test... as a matter of fact, I just filled with E15 last night when I left from work... But the few times I have used it I have not noticed any significant losses... after all, most of us have already been conditioned to E10 @ U.S. pumps across the country... I can't find any station near me that caries ethanol free gas for several years now.
oil pan 4 08-18-2016 06:58 PM
Only up to 10% here.
But I fill up the wifes Hyundai with E0, all the little air cooled machines get E0 also.
rmay635703 08-18-2016 09:36 PM
Originally Posted by roosterk0031 (Post 521004)
June E10 = 42.418 mpg
July E10 = 42.168
August to date E15 = 42.15
I have only recently in last few tanks tried to fill consistently, hence the big tank to tank swings. E15 is $0.10 cheaper so basically 5% at todays prices with at less than 1% mpg loss worst case. They removed the 87 octane E0 that was $.40 higher than E10.
Anybody else using it?
No E15 in our state for at least 3 years, there was e20 up until about 2 years ago, all the blenders went bust in Wisconsin,
backtracked 10 years in the process.
Joggernot 10-06-2016 03:49 PM
Originally Posted by roosterk0031 (Post 524213)
Filled twice this week with E15, first time I thought I must have written miles down wrong and subtracted 100 miles. But after adding up the miles over the weekend pretty sure I had it right. 61 mpg, almost down to half tank today and curious so topped it off same pump and even spilled some. 59 mpg. (DIC indicated 45.4)
After making sure my co-workers weren't messing with me I've decided the pump must be out of calibration. Going to go get a 6 gal jug and fill up a lunch and see how much gas fits in. I'm thinking it will be 4.5 gallons.
Make sure you turn them in for shorting their customers. They should be made to refund the money they got for the short gallon.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
