EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   E85. What's the point? (https://ecomodder.com/forum/showthread.php/e85-whats-point-32650.html)
GhostWolfGT 08-27-2015 07:41 AM
I found the 1 and only E85 station in VA and the price was $2.89!! I paid $2.47 for my ethanol free gas today. Which gives 40% better FE over E85. Regular E10 was $2.17.
So what's the point? Is this normal or are they just trying to screw people over because they are the only E85 seller in VA? (That I've found)
user removed 08-27-2015 09:02 AM
Paid $2.079 for my last tank, with AMex another 6 cents a gallon less. E85 at that price is senseless, maybe why it's the only one? Below $2 a gal in many areas of Va now check gasbuddy for your area?
regards
mech
GhostWolfGT 08-27-2015 09:08 AM
Yeah its close to $2 in my area. I bit the bullet and am testing ethanol free gas this week. Its only 20c higher than my normal station. Last time I tested E-free it was over $1 more than regular back at almost $4 gal in my Jetta. It was not worth the extra cost as it only got me and extra 3mpg.
roosterk0031 08-27-2015 09:17 AM
Here in Iowa the average price spread is 26.5% E85 vs E10, I loose 18-20% mpg with the Impala so E85 is cheaper per mile.
Frank Lee 08-27-2015 09:33 AM
I'd guess the "point" is they got a shipment of E85 at a price that causes them to want to price it that way so they aren't selling it at a loss, and not much E85 gets sold in your area so there it sits while high-volume regular got replenished at a lower price.
RedDevil 08-27-2015 09:37 AM
Depends on your priorities.
CCXR - Koenigsegg | Koenigsegg
When running the CCXR on petrol, the 4.7 liter twin-supercharged Koenigsegg engine delivers 806 Bhp. This already-impressive figure raised to an astonishing 1018 Bhp when the car ran on E85 Biofuel
Whats the point? MORE POWAHHH!
cRiPpLe_rOoStEr 08-28-2015 01:59 AM
E100/E96h is a much more sensible option, as it decreases the amount of cash sent to the OPEC countries more effectively. And nowadays with direct injection becoming widespread in spark-ignited engines, cold-starts became less problematic.
jamesqf 08-28-2015 01:16 PM
When there's a little hiccup in the world economy, and gas goes to $4+ per gallon, that E85 will still sell for about $2.89. It's grasshoppers versus ants, basically.
ksa8907 08-28-2015 04:01 PM
Around here they just keep e85 20-30 cents cheaper, not worth it at that price.
Frank Lee 08-28-2015 04:04 PM
It is if you blend up to 50/50.
GhostWolfGT 08-28-2015 09:06 PM
It never crossed my mind that just because the price of a barrel goes down doesn't mean the price of ethonal does. Thanks.
cRiPpLe_rOoStEr 08-31-2015 06:47 AM
Though some Diesel fuel and petroleum-based lube oils are still used from the cropping to the distillation...
H-Man 09-01-2015 08:07 PM
Here in california, E85 makes sense when a refinery catches fire and gas goes to $4-$5 a gallon (about once every 4 months it seems).
oil pan 4 09-01-2015 11:06 PM
The EPA (Ethanol Production Agency) says we need to have ethanol in our gas.
Ethanol production cost is mostly tied to corn and natural gas prices.
jamesqf 09-02-2015 01:00 PM
I don't think that's quite true. Gas needs octane boosters to work well in modern engines. Lots of things have been used for that, such as tetraethyl lead and MBTE. Those have been shown to have rather nasty environmental effects, so the EPA says don't use them. Ethanol works, is relatively cheap, and environmentally benign, so that gets used.
But E85 is a different thing than the 10% or so ethanol used as octane booster/oxygenator in normal gasoline.
Hersbird 09-02-2015 01:15 PM
But the government requires that 13 billion gallons of ethanol be blended into the fuel supply weather we need it or not. It's not the free market that chose ethanol as the octain booster.
Will Government Mandated Corn Ethanol Consumption Ever End?
cRiPpLe_rOoStEr 09-02-2015 02:32 PM
Ethanol is not a bad fuel at all, but in America it would make more sense to use Natural Gas and eventually biomethane generated at landfills and sewage treatment plants.
oil pan 4 09-02-2015 02:35 PM
Methanol is a better octane booster, would be cheaper and even more environmentally friendly.
Natural gas, coal or wood chips can be used to directly make it. No food crop needs to be grown to make it.
cRiPpLe_rOoStEr 09-02-2015 02:46 PM
Methanol is reported to be more toxic and corrosive.
oil pan 4 09-02-2015 02:47 PM
Turns out bio methane is full of CO2 and actually burns pretty dirty compared to natural gas.
I work with three 1500 horsepower boilers. They were all bought new and installed at the same time.
One runs up to 20% bio gas. Its only 10 years old and had been retubed.
The bio gas boiler also needs to have its tubed brushed twice as often.
The biogas feed line had to be constructed out of very expensive stainless steel. It has to be isolated from the gas circuit, charged up with compressed air and blown out once a week.
The other 2 boilers have almost as many hours and show no signs of need a retube any time this decade.
But that bio gas boiler saves between $1,000 and $3,000 per day, everyday it runs (and it runs about 350 days a year), so what ever the boil men charged for the retube was not even something that had to be though about.
oil pan 4 09-02-2015 02:50 PM
The Gasoline its self is pretty toxic. Methanol is no worse than benzene already found in gas.
Ethanol is also corrosive.
cRiPpLe_rOoStEr 09-02-2015 02:59 PM
Sure, but it's less corrosive than methanol.
jamesqf 09-03-2015 12:35 AM
Well, so is water. Especially if you add a bit of salt to it :-)
RedDevil 09-03-2015 02:40 AM
Ethanol gets less corrosive if you add a tiny amount of water. Or rather, not subtract the last bit of water at great cost.
oil pan 4 09-03-2015 12:31 PM
Good point.
Frank Lee 09-03-2015 02:43 PM
At any rate, some years ago I dropped the tank from the Coupe to replace the fuel pump and it was spotlessly clean, no corrosion and no crud, in a 19 years old at the time non-flex-fuel vehicle with a metal tank. I've never replaced the fuel filter in the 15 years I've owned it. I've run lots of straight E85 through it over the years.
oil pan 4 09-03-2015 04:27 PM
Sounds like they are the Ethanol Production Agency.
jamesqf 09-03-2015 04:58 PM
Yeah, and they require earthquake reinforcement on buildings and bridges, whether or not you happen to be having an earthquake right now or now. Same with fire & flood protections, vaccinations, &c. Remember the old saw about locking the barn door after the horse was stolen?
cRiPpLe_rOoStEr 09-04-2015 09:32 AM
No wonder the "pure" ethanol we use as automobile fuel in Brazil still has some 4% water content measured in volume.
roosterk0031 02-10-2016 02:47 PM
http://energy.gov/sites/prod/files/2...enberg_2-b.pdf
Happened across this on different site. Page 5 they note 18.5% mpg loss from E10 to E85 almost exactly what I've experience with the 2 FFV I've owned.
It seems that Mercedes wants to increase the amount of ethanol per gallon to get a higher octane fuel.
Little more reading on Tier 3 fuels. And where image came from. http://s11.postimg.org/6zbsm997n/ford_ethanol.jpg
http://energy.gov/sites/prod/files/2...omass_2014.pdf
