Originally Posted by Gasoline Fumes
No cooling fan required for the batteries?
Call this a "beta" build. So far the batteries don't even get warm to the touch when pulling 24,000 watts through them, but I'd like to get a bit of airflow through the bay before summer comes around, and it starts approaching 20c (70f) here. Even if none of it is forced through the pack itself.
Originally Posted by Logic
Nice! Looks tidy and professional.
I'm hoping for Watt numbers on the 'flat' highway at different speeds?
Have you any thoughts on range extension for longer trips? I've just read the post with the pusher trailer!
Thanks!
I have around 4kwh in here, but I'm aware of a guy on Insight Central who has 20kwh (around 80% usable) in his, for longer trips. He reportedly can push a continuous, indefinite 20kw through the system in the southwestern deserts of the US. In his case, he expanded the battery pack into where the passenger seat used to be, and built a small deck over it so the space isn't lost.
As far as "flat" highway, I don't think such a thing exists in the country. About an hour and a half north of here there's a stretch of road, maybe 10 minutes long, which has only the slightest incline and is straight, but to my knowledge it's unique in the country.
I've seen the car able to "coast" along with just assist at 80-90kph (50-56mph) with a reading in the ballpark of 3kw (4hp) on the gauge, but I'm incline to believe this must have been ever so slightly downhill, as the number seems implausibly low. I'll do my best to estimate some more realistic numbers.
