EcoModder.com
-   -   EcoModder (sort of) mentioned in a Donut Media Youtube Video... (https://ecomodder.com/forum/showthread.php/ecomodder-sort-mentioned-donut-media-youtube-video-40402.html)
NoD~ 08-01-2022 11:28 AM
https://www.youtube.com/watch?v=p1Ak...t=WL&index=118
Go to 10:04 where he says "There's people on forums..." and there's some screen shots of the site on there.
Again at 10:47, more directly.
Figured I'd share.
oil pan 4 08-01-2022 04:41 PM
They think over inflating tires is a scam.
If done correctly it's fine, if you are going to replace tires soon or have uneven wear over inflation doesn't seem to hurt anything. Over inflating new tires is stupid.
There are no permanent magnets in a car alternator, haven't been for at least 50 years.
They believe running the A/C won't hurt MPG?
Takes about 1.2 to 2hp to run the A/C in my leafs, which is super efficient. I guarantee a less effective belt driven one is eating up more power.
Blacktree 08-01-2022 05:12 PM
Not a fan of that youtube channel. It seems to be targeted to 12 year olds.
Phase 08-01-2022 05:31 PM
i overinflate my new tires...
and they said its better to run the ac at highway speeds than windows down. this is common knowledge though
for example with the ac running in my black ioniq, i can still get 65-75 mpg at highway speeds. im sure it would bump up like 1 extra mpg if i turned it off, but the temperature increase outside also increases the mpg, so it balances out.
oil pan 4 08-01-2022 06:27 PM
I over inflate by maybe 10% on new tires and go max sidewall psi when it's those tires last year on the road and will be replaced before winter.
Phase 08-01-2022 06:31 PM
my door says '' 36 psi'' but i run all my tires at 40 psi usually...
