Ecomodder Wiki alternator disable guide
Second rookie technical question of the day, sorry: I am trying to determine whether my 1998 stock Civic alternator is of the kind that the wiki describes as easy, or if it is of the sort that is more difficult and requires dis-assembly. I have been searching the PDF of the shop manual, but no luck (it might be there, I just have not found it). Does the 1998 Civic have an alternator that the ECU can disable with a signal when it is not needed? Thanks.
How many wires are going into the alternator?
I think that you can disable the alternator by disconnecting the wires I just found this post and it might help. http://ecomodder.com/forum/showthrea...-ex-16012.html
I'll update when things mature more. |
I'm confused. What's the advantage of cutting the alternator if it's still hooked up? Or isn't it?
