Old 01-02-2008, 09:59 PM   #1 (permalink)
stripped down 2000 metro/54.9 mpg
http://www.cardomain.com/ride/2567749
check this out, my last project. totally stripped, best tank was 54.9 mpg with some drafting and 55-60 mph.
joemetro@netzero.net
Old 01-02-2008, 10:06 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Hi Joe -
You might want to stick your location with your other for sale ads. You're gonna get asked anyway.
Old 01-02-2008, 10:08 PM   #3 (permalink)
That's some pretty extreme weight reduction! I'm curious to find out if you weighed the car afterwards (or weighed what you pulled out of it).
Old 01-02-2008, 10:13 PM   #4 (permalink)
bestmapman's Avatar
So do you still have the car. Did you put it back together.
Old 01-02-2008, 10:18 PM   #5 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
Great work. Have you considered a lighter battery? After that, though you may be at the point of diminishing returns - maybe time to try some engine mods.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 01-02-2008, 10:34 PM   #6 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Don't forget putting the driver on a diet The healthy way to vehicle weight reduction
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 01-02-2008, 10:36 PM   #7 (permalink)
You're right, though it might fall under "adjusting the nut behind the wheel."
Old 01-02-2008, 11:00 PM   #8 (permalink)
didn't even think about giving my location, duh. i'm in parma, ohio. i'll have to modify that, thanks.
i wasn't able to weigh the vehicle after but i think i had about 250 pounds off. i would drive it without the passenger seat most of the time, no seatbelts-just a 4 point harness, a motorcycle battery might have worked but i didn't try that. i sold the car about a month ago. the big drawback after removing the dash and heater was that last year it was a pain to drive in the winter, the kid that bought it rigged up a oil cooler (?) and ran the radiator heat through it (it comes with a small fan to disperse the heat inside the car), if i would have thought about that i would have done another winter with it. i even took out my door locks and hatch latch and used a bungee for the hood. i went as far as to take out those supports that hold open your door and everything under the hood that wasn't needed. also i ddin't have a muffler for quite a while which saved about 7 pounds. i would average 45 mpg bcause i drive to fast and it would do 70-75 easily (3 cylinder). next project will be a chevy sprint or an awd toyota.
Old 01-09-2008, 10:43 PM   #9 (permalink)
Paulywog
sip-n-go - '88 Honda CRX
Last 3: 10.06 mpg (US)
Wow!
Mechanical Madness
