Ecowheeler: '94 Ranger 4x4
This will be the build thread for my Ranger. The title refers to my dual purpose build: 1/2 ecomodder transportation, 1/2 offroad exploration, 1/2 work truck. That's three halves. Oh well. And, ideally, all of the below would improve the resale value (though I expect no profit, I just hope somebody appreciates it).
As of this writing I've just finished testing my Ecomodder mods: Done -
Truck testing Done -
Done -
General mods to do:
90 day average: 15.5ish mpg Best (cap, skirts, moderate hypermiling, mostly hwy): 22 mpg Previous tank (moderate hypermiling, half city): 17 mpg EPA: 14/18. Combined 15.8 mpg. Damn, am I seriously above EPA? My mpg is terrible! Goal: 25 mpg tanks (but I'd rather have 30 mpg) |
This will be an interesting thread to watch. I am also trying to beef up my MPG without sacrificing some of my favorite truck qualities. Right now, I haven't had the time or money to do much in the way of ecomods, so it will be interesting to see what works for you. I can say that if you really get into the eco-driving, you will save quite a bit.
I did have a beautiful 2005 Ford Ranger for a while and without any carefully honed driving skills, I was able to get around 18 to 19 on a semi-regular basis. It was a 4.0 automatic, with the added weight of a Rhino Liner. What engine size / transmission do you have? |
Awesome avatar! I also have a 4.0L and auto. I haven't figured out what it is, but it has tall enough gearing to cruise at 60 under 2k rpm. You may have more of a reputation to uphold, but I was able to actually come out ahead on my aero cap and wheel skirt prototypes. The plywood I scrounged will be worth more than I spent in duct tape.
My uncle did a full exhaust and chip to his, plus a standard canopy and 200lbs storage drawer, and he gets almost 25. So, I don't think that's an unreasonable goal. Suffice it to say he is not familiar with ecomodding. And, at 10 mpg over my current average, I'll be saving a lot! |
http://ecomodder.com/forum/picture.p...5&pictureid=75
I was salvaging from the scrap bin at work and decided to aero it up while I was there. A small pallet is against the cab window, sawed on one end for the right height. Three sheets of ply form the base, one forms the angle. Attached flow all over the place! A final version would open like Bondo's, and hopefully weigh 100lbs less! http://ecomodder.com/forum/picture.p...5&pictureid=77 Note clearance at front corner of tire is about .5", but no rubbing has been noticed. I had to wad up a cardboard shim for the fender flare to get the clearance right. I think this is the right shape for trucks. Sort of inspired by motorsport blister fenders. My bedliner had a little gap along the rails that I shoved the cardboard up into, then taped the seam. http://ecomodder.com/forum/picture.p...5&pictureid=76 Hopefully I can get some photos of tuft testing in action. The ones on the wheel skirt line up starting at 15 mph. I taped out to the bumper to mitigate the parachute effect. The sides are mainly cardboard rectangles, scored and folded over the plywood. The air almost follows the red tape angle, but actually cuts a little sharper up onto the top. One tuft on the side did poke up above the fold, but we added some tufts just inboard from there and the flow seems to re-attach and turn to the rear. All tufts on the plywood point straight back. My WWU VRI buddy warned I might get a venturi curling off the trailing edge, but strings undearneath show calm air behind the tailgate. http://ecomodder.com/forum/picture.p...5&pictureid=78 Just black duct tape. Still trying to figure out how to do an air dam. First step is to get rid of the stock one, which I highly doubt has any function other than to limit my approach angle. Highway testing after the cap and skirts showed lower than normal coolant temps, and the grill block maybe brought it back up to normal. Still, most small Fords (mine included) overheat, so I plan to switch to an electric fan (which will also help FE) and duct the air up through a hood vent. Any final grill block would be quick release, just like the rest of it. The tape is covered in bugs after one drive, so I think I'm getting some brick effect. Future plans, then, would be a more angled nose. So, although there may be better angles, I did pretty well for my first try. I'm open to ideas! I need the bed soon, so a-b testing will occur soon. Then I'll get to see how bad mpg is with a lumber rack. Yuck. |
Awesome work so far! I hope to fashion an aero cap before too long. I think that will prolly be my biggest fuel saving mod, other than my Scan Gauge.
You said you were considering an air dam, but if you are planning to off road your vehicle, wouldn't skid plates work a little better for you. They may clean up the belly of your vehicle and have the added benefit of protecting your underside from those pesky rocks and stumps. Any gaps in the plates could possibly be bridged with coroplast or some kind of filler material. The plates would prolly be a lot more expensive than a home-made air dam, but it would be a justifiable cost if they protect your transfer case and stuff from being punctured. Just a thought... |
Oh, and be sure to add your vehicle to the EM garage.
Welcome to EM. Not bad flex out of a Ranger ;)
OK, I added my truck. Since the photo above I taped shut the lower air dam hole, the light holes, and half the bumper hole. Only half that hole is shrouded into the radiator.
Did another big trip, 20.3 mpg, to visit my dad. More city than the 22 mpg trip, to visit my mom. He liked it a lot better than she did: "Cool! Scientific investigation!" vs. "Oh. We'll take my car to dinner." Can you guess who's the engineer? That flex is with swaybars in place and overload springs, too. I figure it's ok. What I need is some more up travel; it bottoms out after maybe 3". The next few days will show whether it was really worth a damn aerodynamically. Either way, tomorrow my aero cap is turning into a storage shed :) |
Looks good!
http://ecomodder.com/forum/member-nw...-scrap-bin.jpg I would say................... "Looks like hell, but if it's just a prototype for something better, then yeah" :thumbup: |
That's fair. At a distance, especially from behind, I find it an appealing shape. And, with the side covers off and dents showing, I rather prefer the cardboard :)
As mentioned, I took everything off. Even with a bit of rough terrain, the side covers didn't rub the tires. Looking at my fuel log and driving behavior, I don't think the 6 traffic lights I drove through should be enough to kill 2mpg from my best. Also, compared to the previous drive, I coasted my ass off and still came up a little short. So, there may be some truth to my perception that it coasted better with the aeromods. But was it the weight or the shape? I'm hypothesizing that 200lbs of sand won't give me 2 more mpg, but I guess I have to prove it. Also, scientific accuracy would require the mods to be tested individually rather than just as a group. However, since my goal is max efficiency and nobody is paying me for these tests, I may not bother. The hypermiling tactics on this last tank were approaching PITA. If mild, intelligent behavior and no mods brings me back down to 15-17mpg, I'll add the mods back on in short order. And, if I can get it to look good, then I'll be inspiring people rather than repelling them. |
I'm brainstorming a similar project in the thread hypermile homestead vehicle, I knew there would be other people into a high mpg 4x4 :thumbup:
Keep up the good work! |
