EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   effect of wheel offset on mpg (https://ecomodder.com/forum/showthread.php/effect-wheel-offset-mpg-24487.html)
rav 01-02-2013 06:53 PM
I am planning to swap the steel wheels on my Honda fit with a 55 mm offset with lightweight alloy wheels with a 45 mm offset. If i understand offset correctly, my wheel will stick out by about 10 mm from the fender. Will the gain in mpg by lighter wheels (low rolling resistance) be more then the additional drag caused by the wheels sticking out or I am just being paranoid and 10 mm will be barely anything at all.
Sporty Modder 01-02-2013 11:24 PM
I dont think it will be a problem, 10mm is only a touch more than a 1/3rd of a inch. Aero shouldn't be affected esp if the rims and tires are still in the fenders.:thumbup:
YeahPete 01-03-2013 01:02 PM
What about when you go over an unexpected bump, won't your tires wack the crap out the top of your fender? Don't think you'll avoid all bumps because all it takes ia one good wack to leave a pretty dent.
mcrews 01-03-2013 03:49 PM
THe 10mm is not from the fender.
THe 10mm is added to the current outside edge of the tire. I dont think it will rub, but you should measure. Again, from the outside edge of the tire.
wmjinman 01-03-2013 04:18 PM
Whoa! Just gave me an idea: get offset wheels the OTHER direction for the rears & then can do a more "complete" fender skirt!!!
mcrews 01-03-2013 05:36 PM
there you have it!
botsapper 01-04-2013 12:44 PM
..so you can tuck in all the wheels inside all the skirts...
http://s.images.boldride.com/saab/19...197314-304.jpg
http://images.thetruthaboutcars.com/...97a-119008.jpg
Sven7 01-04-2013 06:09 PM
crews is right.
http://recstuff.com/images/trailerfa...-backspace.gif
Offset (wheel) - Wikipedia, the free encyclopedia
It should not make a discernible difference in fuel economy.
Frank Lee 01-04-2013 06:32 PM
The Bonneville speed guys carefully place the wheel offset for minimum drag. That said, I don't know if you can do it by eyeball, and furthermore at highway speeds I doubt it makes a detectable difference. But if you are going whole hog, it should be investigated via tuft tests or ?
Sven7 01-04-2013 06:37 PM
Or go to one of those speed runs at airports and do coast-down testing from 100mph. You'd need to have the same tires on each set of wheels, though, for consistency.
AeroModder 01-06-2013 01:15 AM
Best way to test this is to pick up some hubcentric spacers and see what happens.
wmjinman 01-06-2013 02:05 AM
But how to test the opposite direction offset?????
AeroModder 01-06-2013 11:40 AM
Pick up a set of wheels with a high offset, then gradually move it out with spacers. If you change the wheel design, that will affect the airflow and it won't be an apples-to-apples comparison.
rav 01-12-2013 01:35 PM
Thanks for the replies just ended up getting one of the most lightweight and aerodynamic wheels that Honda made:
http://i53.photobucket.com/albums/g5...ps2352c199.jpg
Best of all they are made for a Honda fit with the same offset!!
Vekke 06-09-2022 04:06 PM
I am at the moment doing CFD simulation to the offset matter. I am using a Drivaer 3d model with just drivers side and front wheel. Wheel is fully closed in the simulation so there is no cooling holes at the moment. So far it seems that if you move wheel inwards it helps with the drag. In first simulations wheel is not rotating.
- mm is inward movement
+mm is outward movement
+40mm 0,4961
+30mm 0,4870
+20mm 0,4908
+10mm 0,4896
STD 0,490
-10mm 0,4926
-20mm 0,4900
-30mm 0,4829
-40mm 0,4835
Next I will put convex hubcab there which will come outwards +20mm at the center. And for next runs I will also take down the actual forces as the frontal area changes little bit so the drag coefficient calculations are not exact. Frontal area grows from A=1,0218m2 to A convex capsels=1,0226m2
My guess for sweet spot is between -20 to -30mm range. Specially when wheels are rotating
After that I will try to put it then rotating. Pics will follow later
Phase 06-09-2022 10:02 PM
+40mm 0,4961
+30mm 0,4870
+20mm 0,4908
+10mm 0,4896
STD 0,490
-10mm 0,4926
-20mm 0,4900
-30mm 0,4829
-40mm 0,4835
any thoughts on the hyundai ioniq blues hubcaps?
