Effects of speed, wheels, temp on EV range
As illustrated by Renault
Scroll down to "Simuleer uw rijbereik" to play around with speed, temperature, wheel size and see how it affects range. https://nl.renault.be/voertuigen/ele...agens/zoe.html Pour les francophones : https://fr.renault.be/vehicules/vehi...iques/zoe.html |
It sucks.
I'm pretty sure below 45F I won't be able to make it to the big chain hardware store and back with my leaf and trailer with out stopping to charge. |
Maybe you'll have to browse for a bit longer to let the Leaf get enough charge? |
With 120v power I would pick up around 1 mile per 15 to 20 minutes of charge in winter.
But I would need it. |
This flirting with freezing temperatures has nearly cut my range by around 20%.
If I use the heater, even more. |
If you plan your trips carefully, you can set the car to finish charging just before you depart to give you the longest range and warmest battery. I used to set my Prius to finish charging just prior to departing. It had the ability to either begin charging at a set time, or to set the end of charging time and it would adjust when it began based on the end time. Using the HVAC heater will drastically reduce range. Seat/steering wheel heaters take hardly any power at all. |
I can clean, rearrange and relocate items in my garage and put the leaf in there with my coal furnace and do what I have always done with gas and diesel vehicles where I put a little electric space heater in the car and run it for a bit before driving.
I started doing this in 1998 when I moved to maine. |
I wish GM had installed a heat pump instead of the 5 kW resistance heater. |
Looks like during cold weather I lose a minimum of 10% and a maximum of 25% range. But I use the least heat I can tolerate, i MUST use the defrost or the windshield fogs very badly.
I don't think im losing range but I do get horrendous sag when its below 70f. Enough to trip the low battery systems. I do prewarm the cab and batteries from house power.
On cool freezing days I'm down about 20% on energy economy and that's rarely using the heater.
Over all the leaf is doing better than I thought it would but the cold is a lot worse than what I thought it would be. And it hasn't even really gotten cold here yet. |
Hmmm my Volt batteries seem to keep the same capacity, current falls and the sags are huge. I am not using heat.
The volt batteries are under rated and over built so they could find the power within to overcome the cold, if the batteries are not being heated.
Lithium batteries really suffer in the cold. I have been using them since 2010. |
