Old 01-31-2010, 01:37 PM   This thread is in the EcoModder Project Library | #1 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
New undertray design
After finally getting around to building my undertray, I got the two middle panels in. My biggest problem was space underneath the car, but I figured out a way to lift the jack higher.
Here are the two middle panels. you can see they're trimmed around the exhaust so it doesn't trap heat and/or fumes, or melt the coroplast.
Here's a picture of the front undertray I've had for a while.
There was a definite reduction in wind noise, as well as a jump in economy. My estimate is a 5 MPG gain on the highway. My daily 40-mile commute used 2/3 as much fuel than before.
Photos of the rear panel of the undertray to come, when it's finished. I'm still working on the diffuser fins.
The Following User Says Thank You to AeroModder For This Useful Post:
Piwoslaw (02-01-2010)
Old 01-31-2010, 02:15 PM   #2 (permalink)
rav
Gas HOG - '08 JEEP LIBERTY SPORT
Looks awesome, great job!!
Old 01-31-2010, 06:03 PM   #3 (permalink)
AeroModder's Avatar
Team Ford
Thanks!
Here's the final touches on the rear diffuser and undertray panels:
I left an inch of coroplast off of the end of the bumper so the airflow separates cleanly. I put another panel on the side to seal off the open area under the trunk, and made sure to fold some of the material up so it doesn't have a parachute affect. The other side is open, though, since I need to leave the muffler in open air.
Old 01-31-2010, 06:33 PM   #4 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
the rear verticle fins look like the ones one the fusion 999 flats racer, what specicly dop they do
Old 01-31-2010, 06:58 PM   #5 (permalink)
AeroModder's Avatar
Team Ford
They make sure the air moving through the diffuser stay straight and non-turbulent as the air pressure drops back to the ambient pressure.
Here's a thread from here on diffusers: http://ecomodder.com/forum/showthrea...read-8313.html
Old 01-31-2010, 07:51 PM   #6 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Nice
Old 01-31-2010, 10:11 PM   #7 (permalink)
AeroModder's Avatar
Team Ford
Now that I'm looking at it more.. I found out that the maximum angle of the diffuser is 25 degrees, which is far sharper than most. However, at slower speeds, I don't think this will make much of a difference. If I needed to, I could just add a few strips of coroplast between the diffuser and bumper as a spacer.
I could also put a smaller piece on the other side, but I'm concerned about the lack of mounting points on the open side. What do you guys think?
Old 02-01-2010, 01:45 PM   #8 (permalink)
2.5 vs 25
I believe that would be 2.5-degrees,not 25.The panel can go as steep as 4-degrees,depending on where it begins under the car.It's in Hucho's book.
Old 02-01-2010, 02:36 PM   #9 (permalink)
AeroModder's Avatar
Team Ford
The edge of the diffuser is 25 degrees from the horizontal.
I actually don't have Hucho's book, but I've heard it referenced quite a bit. Now, is there a certain angle-per-length requirement before the airflow detaches, such as no more than a 4 degree increase per foot of panel lenght?
Now I'm curious. *scurries off to do more research*
Old 02-01-2010, 02:53 PM   #10 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Here's the figure from Hucho's book. Best angle is dependent on the aspect ratio of the diffuser (diffuser lenght/underbody lenght)
www.HyperKilometreur.com - Quand chaque goutte compte...
The Following 2 Users Say Thank You to tasdrouille For This Useful Post:
aerohead (02-01-2010), AeroModder (02-01-2010)
efficient engine design user removed EcoModding Central 27 11-24-2014 01:02 AM
PCB design for led bargraph battery monitor mora DIY / How-to 30 10-20-2011 11:02 AM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Civic grill block, front undertray, tire deflectors daqcivic Aerodynamics 24 05-13-2009 03:52 AM
