Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-09-2008, 04:31 PM   #1 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
Air sealing!!!!
One of the biggest engery wasters in houses is leaks. Most houses are very leaky. The older your house, the more leaky it is likely to be. The cost of sealing is pretty low, but it can be time consuming.
The mian expenses are things like silicone caulk, expanding foam, insulation, etc.
I pulled off the trim around all my windows and doors, and sealed between the frame and drywall. I sealed around all the outlets. I replaced some of the seals in doors and windows. I went around the outside of the house and seal under the siding where it overhangs the foundation. Around pipes and cables entering the house. Anywhere I thought air might be coming in or going out.
I had had a blower door test before and after, and manage to reduce the leaks by about 1/3rd. I have done sealing since then.
I have also done stuff like programmable thermostats, CFL lighting almost completely through the house, motion senser lights in the garage (this can be a little annoying when are out of their line of sight). I also insulated a kneewall. All these things add up.
But the air sealing of the house has made the biggest impact to our energy costs. And it really didn't cost a lot of money to do it.
GreenCarMPG.com
Old 07-09-2008, 05:53 PM   #2 (permalink)
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Yup. Think of it as an upside down swimming pool of heat.
Good design is simple. Getting there isn't.
Old 07-09-2008, 06:41 PM   #3 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I'll second that.
I've spent lots and lots on sealing up the house however mine was SUPER leaky.
I've wondered if there is a DIY fan test . . . . . anybody rigged something up?
I can still get a solid breeze out of a door on a windy day. (was higher than wind speed before LOL)
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-11-2008, 06:50 PM   #4 (permalink)
Wicked Wanda - '99 VW Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Ford Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Honda Odyssey EX
90 day: 24.23 mpg (US)
Many electric companies will come out and do free energy audits. I had one done last winter and he used a thermal camera to document where I was losing energy. I have it on CD. I'll see if I can find it and upload it somewhere to be seen. It's cool.
Old 08-20-2008, 04:56 PM   #5 (permalink)
when I was younger,a repairman came to work on our heating system.He made a comment to my mother about weatherstripping.She didn't think it was an issue.He said,you have three doors.Each has a perimeter of about 20 linear feet.If you had a 1/8 inch gap around each door,it would be equivalent to a 3-inch diameter circular hole in your wall,large enough to shove your hand through.At that moment my mom and I just looked at each other,he had made his point.
Old 08-20-2008, 08:29 PM   #6 (permalink)
EV OR DIESEL
awesome I'm going to use that argument a lot now
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
