EcoModder.com
-   -   Electric A/c conversion (https://ecomodder.com/forum/showthread.php/electric-c-conversion-3950.html)
lovemysan 07-20-2008 06:30 PM
I want to convert may a/c system from the belt driven compressor to hermetic type compressor. Does anyone know the aprox btu output of a small cars a/c system. My guess would be not more than 8000 btu for my car. I would think that the 7 amp compressor could easily keep up. Of course this all arm chair theory. BTW I take 20% loss of economy running the a/c.
Daox 07-20-2008 09:06 PM
The only tid bit I can offer is that the Prius' electric AC compressor is run off the main battery pack instead of the 12V system.
lovemysan 07-20-2008 09:17 PM
Yes I read that also. Its because the higher voltages allow for smaller parts. I found a 5k btu Marine 12v system that draws 45 amps 12 v dc. The compressor will cycle so its not a constant voltage. The goal is to do this as cheaply and easily as possible. I'm thinking of running a test. Put a 5k btu a/c in the trunk blowing into the cabin via the seat folded down. Running on my small generator. This would tell if its feasible. I'm pretty confident it would be enough. The next question would be where or how to find a 12 volt compressor that would work well with the current hard parts in the car. Mainly the condensing coil and evaporator coil. My current a/c is horrible. How many HP does it take to make 45 amps?
dremd 07-21-2008 12:16 AM
I've heard that the average car's A/C system is powerful enough to cool a normal 2000 square foot home in Atlanta.
Might look in to a variable displacement compressor (Love mine!) before going electric.
gascort 07-21-2008 12:28 AM
You also need a way to push a lot of air through the condenser in the trunk. The efficiency of your unit will depend a lot on this.
If you know someone in the refrigeration industry, maybe you could have them hack up the 12V system and fab it into your evaporator and condenser.
Daox 07-21-2008 08:11 AM
45A * 12V = 540W
540W = .72 hp
I've heard (not from an expert) that an car's AC system is comparable to a household window unit. Of course those vary widely in size so...
extragoode 07-21-2008 09:14 AM
I would think that in WI you would be in the same situation as I am here in IA in that you have the A/C for dehumidification as much as cooling, so it may not require the SAME size system as the car anyway. I just wanted to mention this in case you hadn't already thought of it. I know for me, I just need a little more something than the vent, cause they don't do much when it's hot and humid.
lovemysan 07-21-2008 12:24 PM
I have a variable displacement compressor. However mine is mechanically controlled and resource hog. Some of the more advanced units are electronic and more efficient. I had a standard system in my old nissan truck that was more efficient because it rewarded the judicious a/c user with intermittent cycling. MY VDC doesn't cycle and never seems to change the amount of power necessary to provide the minimum amount of cooling. I tried setting the fan to low and different temp settings to no avail the FE was all the same. The temp control on my car merely mixes hot(drawn from the heater coil) and cool air together causing increased loss of eff. I find that manually cycling the compressor does yield increased FE. This thing siphons off a serious amount of power I est. 8-10hp.
metromizer 07-21-2008 02:28 PM
I think you will be disappointed with driving the compressor with an electric motor, that is driven off the alternator. Reason? every time you convert one form of energy to another, you loose efficiency. I have wondered about efficiency ratings for compressors for years, but it seems to me that unless your car is an EV, the most direct drive approach will be the most efficient.
Running that a/c compressor and coupled electric motor off a bank of 'on board batteries' however, that you charge up from a solar photovoltaic system, might have running your car's a/c system for nothing.
Originally Posted by lovemysan (Post 46023)
I had a standard system in my old nissan truck that was more efficient because it rewarded the judicious a/c user with intermittent cycling....
I owened couple of 'hardbody' Nissans in the 90's and really liked that a/c feature. I would turn off the a/c buttom while getting on a freeway or climbing a grade. Too bad the 2.4 liter wasn't a little more frugal with the fuel
MY VDC doesn't cycle and never seems to change the amount of power necessary to provide the minimum amount of cooling.... The temp control on my car merely mixes hot(drawn from the heater coil) and cool air together causing increased loss of eff.
It just doesn't seem right, almost ridiculous, doesn't it? Yet most automobile a/c systems are set up that way.
elhigh 07-21-2008 04:16 PM
If somebody comes up with a really feasible idea, let me in on it, okay? My truck has no AC at all, and here in the Bible belt we get pretty hot and really humid - opening windows just stirs the sticky around, and swamp coolers have no effect whatsoever.
lovemysan 07-21-2008 08:46 PM
I think your right. There would be a serious eff loss using the electric motor drive method. Unfortunately for me I have limited resources and limited amount of time. This project will probly never get off the ground.
Piwoslaw 04-07-2010 12:53 PM
These may be of interest:
How much current does the A/C compressor draw? - GreenHybrid
Prius Air Conditioning System [PDF]
Electric Inverter A/C System for TOYOTA PRIUS Hybrid Vehicle [PDF]
The third link shows that the Prius' electric A/C compressor uses 19% less fuel compared to the engine driven compressor of an older Prius version.
Since the Prius' A/C system uses higher voltage, the compressor itself is 40% smaller and 53% lighter than a conventional electrically driven compressor.
The Prius' system is electric to allow the use of A/C while in stealth (engine off) mode, so I wonder if this will be adopted in more cars as gas-saving engine start-stop systems become more popular? I guess that the major obstacle is the power needed. Running the A/C @ max at a 90-second red light may drain your battery enough to leave you stranded. High voltage systems, where are you?
fatman57 04-09-2010 04:05 PM
I was recently thinking of doing this to my car. It doesn't have air conditioning and is a mid-engine car so I was thinking of a front install.
I agree that any change of energy souce will add losses to a system - will not a DC motor do?
Or more radical how about getting A/C from the alternator BEFORE the diodes while still allowing current to flow to them to feed the rest of the car?
photovoltaik 08-26-2010 07:37 AM
An inverter is an electrical device that converts direct current (DC) to alternating current (AC); the converted AC can be at any required voltage and frequency with the use of appropriate transformers, switching, and control circuits
sid 08-27-2010 10:13 PM
Add a thermostat to turn your A/C clutch on and off. I designed and built my own out of parts I had laying around the house (I'm an electronics engineer). But, prior to this, I was using a household wall thermostat to control the A/C clutch. The reason I ended up building my own is that the wall thermostat I used (which was also laying around the house, hence, free) had too much hysteresis (wasn't cycling enough, would get too cold and then too hot, needed to switch more frequently), but it was better than nothing.
Maybe there are off the shelf thermostats that have adjustable hysteresis. I didn't research it as I was too cheap to buy a new thermostat and could quickly build my own for free.
BamZipPow 08-28-2010 08:48 AM
In this thread I started at 4x4wire I came across the Dwyer Instruments TCS thermocouple controllers which may work fer yer setup. They are industrial controllers so they are very robust and durable. The price might scare you away...but sometimes if you want consistency...you need to pay the price if you can't design/build one on yer own. :D
Just so you know...I never did hook up my TCS module...but I still plan on using it on my truck fer something. ;)
