An electric car for the rich
Using induction charging just for looks, which is less efficient than connected charging.
Bah ! |
How gauche. ;) |
All joking aside, there is a good reason to go with induction charging:
"HaloIPT’s wireless charging systems use inductive power transfer (IPT) to transfer power over gaps of up to 400mm (15.75 inches) and are tolerant to parking misalignment with power transfer efficiencies that can match a plug-and-cable. The company is currently delivering units in the range 3 to 7kW and is also developing higher power 3-phase systems for public charging." "The technology is designed to function beneath asphalt, and works under water or covered in ice and snow. IPT systems can be configured to work with all road-based vehicles from small city cars to heavy-goods vehicles and buses. With IPT technology embedded into roads, cars could also be charged on the move. This dynamic in-motion charging would reduce battery size requirements as well as providing charging convenience, the company suggests." HaloIPT is a technology development company founded by Auckland UniServices (NZ) and Arup (UK). |
Not to mention that watching doesn't really count. The Jeeves & Bertie stories are books, so you need to read them for accurate information. IIRC, there were several models mentioned (all imaginary), including the Widgeon Seven. |
Charger loss, battery heat (another loss), if you look a bit further, wired transmission losses in electricity distribution networks, ... Adding yet another loss through radiated power transmission, is simply not acceptable. Aside of the fact of wether or not we even want more high-powered radiation around. |
Fair enough, but there's still the point that with IPT technology embedded into roads, cars could also be charged on the move.
