EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   Electric Motorcycle Blows Up!!!! (https://ecomodder.com/forum/showthread.php/electric-motorcycle-blows-up-2809.html)
bennelson 06-04-2008 05:04 PM
:mad:
OK, well, no giant fireball, as there was no gasoline involved.
I was stopped at a three-way stop sign. When I went to pull away from the stop sign, it didn't go and a giant plume of smoke puffed up from under the seat.:mad::(
I hit all the power and disconnects and pushed it out of traffic.
I walked 2.5 miles home, stopping at the former Curtis controller guy's place.
He seemed to confirm that the problem was most likely the controller. I saw NO damage to the DC/DC converter or the main power contactor. I didn't see anything wrong with the motor, but it's hard to see anything without the cover off anyways.
Yep. I just walked in the door and the first thing I do is post a message about it! Haven't even had a glass of water left.:rolleyes:
MetroMPG 06-04-2008 05:09 PM
Bummer!! Maybe related or not - but did you have a pre-charge resistor in the circuit?
Got warranty?
ttoyoda 06-04-2008 05:25 PM
You let out the magic smoke. Everyone knows electronics don't work if you let the smoke out. ;)
On the serious side, maybe you just blew out an electrolitic capacitor. The plates can short, the electrolyte boils out, lots of smoke.
If that is all, it should be an easy fix.
bennelson 06-04-2008 05:35 PM
Got warranty?
Yes, I did. I believe the pre-charge resistor only effects the controller when turning the contactor on and off, which is only done manually at the start and end of a ride.
It sure was a lot of smoke.
Just got back with the cycle in the back of the S10. I lowered the back, but haven't had time to lower the front yet. Sure rides low with the blocks AND a cycle loaded in it!
Daox 06-04-2008 05:45 PM
Sorry to hear that Ben. Hopefully you'll have it sorted out soon.
bennelson 06-04-2008 06:48 PM
Yep, it's the controller.
See the pix.
Notice the hole?
http://gallery.mac.com/benhdvideoguy...C06285/web.jpg
This is what it looks like from the other side.
http://gallery.mac.com/benhdvideoguy...C06288/web.jpg
The inside of the controller has epoxy filled in there so it's totally waterproof. When this thing went, it must have blasted a hole right through the end there!
That also means that you can't just get in and replace a single electronic part.
I am calling Alltrax customer service tommorow. Why do I have the feeling my one year warranty just expired.
See all the photos here:
http://gallery.mac.com/benhdvideoguy#100075
ttoyoda 06-04-2008 08:00 PM
Also it makes it that much harder to reverse-engineer/check-for-patent-violations.
There are epoxy removers that claim to be "safe" but I think the PC board has epoxy in it..
http://www.fiber-tensioners.com/BIO-SAFE1025specs.htm
SVOboy 06-04-2008 08:00 PM
Total bummer!
bennelson 06-04-2008 08:44 PM
Actually, I did just dig up the original purchase date info.
Yep, if it was a one year warranty, it was up last week!
ttoyoda 06-04-2008 08:48 PM
But was that date the order date, or the date it arrived and you had possesion? Because I would think the warranty would start when you got your hands on the part.
zjrog 06-04-2008 10:56 PM
I'm an elect tech... And I thought I was the only one that said that!!!!
MetroMPG 06-04-2008 11:51 PM
Ben - I wonder if it's a coincidence that this happened so shortly after you upgraded your pack voltage. I know it's rated for 48v, but what might the peak charging voltage be on your new charger? (Your controller probably isn't electrically connected when charging, is it?)
WaxyChicken 06-05-2008 02:40 AM
Wow. This is the first EV casualty I've ever herd of. Thanks for sharing, Ben N.
I wonder if by chance the batteries charged to a state that the controller couldn't
properly handle.
does Alltrax have a bad rep by any chance? soon i will be looking for which brand
controller to buy.
Another thought - do you still have the forklift's controller lying around or are you planning to use that with your metro?
Best of luck on repairs. :)
Lazarus 06-05-2008 08:12 AM
They might work with you on that, call and talk to them. Maybe they will give you a cost break on the next one.
bennelson 06-05-2008 09:36 AM
Here's the voltage specs on the AXE from Alltrax's web page:
"Type: DC "SERIES WOUND" motor controller
Undervoltage cutback: adjustable, 16-30 VDC
Overvoltage shutdown: adjustable,
30-60 VDC (48V models) (60VDC MAX)"
The highest I have ever seen the battery pack voltage at was 55 volts.
The controller is disconnected from the pack while charging.
NoCO2 06-05-2008 10:00 AM
That's really a shame to see. Hopefully you get it all sorted out quickly so you don't have to burn too much more FF to get around!
Ryland 06-05-2008 10:02 AM
It's worth calling them up, it never looks good on their part to have their product fail like this, even more so on a vehicle that is in public view.
bennelson 06-05-2008 12:00 PM
Preliminary good news.. I looked up and found that the Alltrax has a TWO YEAR WARRANTY!
I got a call back from the warranty guy at Alltrax, saying that the best thing might be for me to contact the company I purchased the controller from, because I might be able to get a new one faster that way.
I am still waiting on a call back from my original dealer.
johnpr 06-05-2008 12:09 PM
i hope this gets sorted out for you shortly, such a bummer that it happened though.
ebacherville 06-05-2008 12:21 PM
bummer it happened yes but if you get a replacement thats great ... it was flawed if it burnt up with in a year.
bennelson 06-05-2008 05:17 PM
Got an e-mail from my dealer.
I am supposed to ship the original back to the manufacturer and the dealer will be shipping me a new one out tomorrow!
Yea, warranty coverage!!!!!
COMP 06-05-2008 05:20 PM
congrats:thumbup:
Daox 06-05-2008 09:24 PM
Nice!
johnpr 06-05-2008 11:35 PM
happy that its working out for you :)
bennelson 06-06-2008 05:53 PM
Bicycled to the post office today and mailed the Alltrax AXE back to the manufacturer.
Much quicker on the motorcycle than a bicycle....
ceo hank freid 06-18-2008 06:02 AM
Its very awesome Motorcycle. Thanks for sharing this one.
:turtle:
bennelson 06-18-2008 07:40 PM
(Ben is currently on the road)
Last time I talked to my wife on the phone, she said the controller has shown up in the mail!
Yea!
dremd 06-26-2008 09:07 PM
I'm sure you've seen this; Modded electric motorcycle is street-legal, costs under $2K - Engadget
But regardless Congrats on the coverage :-)
Maybe the publicity can make up for the burnt controller? Ok, Maybe not . . . .
bennelson 06-29-2008 11:36 PM
Motorcycle is back together and works great!
Went off-roading at the MREA energy fair....
Johnny Mullet 06-30-2008 12:00 AM
That's good news bennelson.
