Electric motorcycle / scooter motor ??
Has anyone used any motors / controllers from this company out of china?
They sound quality and the specs all look good, here are copies of some prices etc. Any comments are appreciated! I'm thinking about this hub motor / kit for a DIY scooter or motorcycle conversion. I currently have a 2010 Kymco Xciting RI 250 but will sell this and get a cheap(broken) bike. Just trying to figure out the best option for a city(45mph) cycle that could carry me(180lbs) and 25lbs of cargo. I'm also very curious about the lithium titanate technology. Battery is twice as much as LIFEPO4 but has 30000 cycles and if regen is set up right it should regen much more than the normal vehicle even though bikes don't usually weigh enough to make good use of regen this might be pretty good if regen(brakes) is twice the amps of degen which is backwards of normal LIthium ion EV's. Please tell me what you think, 10kw 72v hub motor with wheel for $630 or 5kw 72v hub motor with controller and throttle for $500 Thanks from Fox in KC! Dear Fox, Glad to get your inquiry of your 10kw from alibaba. I am Helen from Changzhou Leili Vehicle Parts Co.,Ltd. See the following points: 1.The unit price of your 10kw motor with 16" integrated rim is USD630.00 2.See the picture of your 10kw motor with 16" integrated rim in the attachment. 3.Tell me your detailed address,your postal code for your one set so that i can give you shipping cost for your reference. 4.Pay attention:The rear 10kw motor's drop out is 200mm. ************* Changzhou Leil Vehicle Parts Co.,Ltd ADRES:No.13,Xinya Road Minghuang Gouna Industrial Park Wujin distrc, Changzhou City, Jiangsu. Website:htp:/leicn.en.aliba.com E-mail:heln@leicn.et 72V 5000W ebike KIT 1)72V 5000w rear ebike motor with spoke and rim- - - - - - 1 PC 2)5kw progamed controler(80 AMP curent,24 mosfets)- - 1 PC 3)twisthrotle withre sped model- -1 PC 4)brake lvers(for both side power of)-1 Pair |
I am riding a Chinese scooter that probably was sold by Alibaba. Many miles - no problems but it is making a "worn brushes" sound when cold. 2 to 3 years something else might be worn.
About 2 years ago Alibaba had a closed wheelchair vehicle with 4 hub motors for $7500. Still too high- bought a Ford Ranger for $7000. Alibaba must have sold a few- they are being sold in southern CA. for $18000. up. I guess those hub motors work! |
I think I'm on that path. I just got a full quote to my door for kit minus batteries
10kw with 20kw peak hub motor on 21" motorcycle wheel(no tire) with full regen kelly 400A controller throttle and brake levers for $1600 |
